drag strip
I know this another one of those annoying "what do you think..." questions, but I really am curious as to what you people out there predict I will run in the quarter mile. Here's my car:
1989 CRX Si
'96 D16Y8 motor running off '95 OBD-I P28 ECU, with my Si trans
AEM Cam Gear (I know I know... it came with the engine)
Flowmaster 2.25 inch exhaust, no resonator
Modified CRX Si stock air intake
stock exhaust manifold
completely stripped rear hatch area
weight= about 1960 lbs (at the truck scale)
Stock wheels and old dunlop D60A2 tires
So what do you all think? I ran a 16.1 with my old crappy D16A6... will this one be much stronger? Also, any recommendations as to what RPM I should launch at? How about what RPM should I shift at? Any advice?
Thanks
1989 CRX Si
Thanks
the way my friend launches is to drop it a 6500, come off the gas for a second, then floor it. launch in vtec! this is in a b16 hatch with cams and a lot of other stuff.
my guess is high 15's for you.
anyon else?
