What radiator setup for h22 eg?
I made the stock civic thin radiator with the thick fan work with my h22 by notching the fins and it has been working but i want to upgrade and get a nice radiator with a thin fan does anyone know what radiator and fan would be good to go with and would fit properly? Thanks
the H22 FAQ thread will answer this, but the single core radiator is said to good enough for regular city driving but will overheat on the highway. Most people running h22's recommend to run with nothing less than a stock dual core radiator or an integra radiator
Well I for one have an h22 in my teg and I have a single core stock radiator and can say with confidence my motor has never overheated, the needle never even has reached half temp. U should be fine with just the single core radiator.
God Speed Aluminum Thick 2" radiators I believe are around $160 on ebay 92-00 half size and I would get a slim fan the pushes more air. There is a couple of dealers on here that sell the slim fans for about $60 shipped and I believe a 12" fan will fit. Use the stock honda plugs for the fan just need to swap wires if your pushing or pulling.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST »</TD></TR><TR><TD CLASS="quote">Well I for one have an h22 in my teg and I have a single core stock radiator and can say with confidence my motor has never overheated, the needle never even has reached half temp. U should be fine with just the single core radiator.</TD></TR></TABLE>
An Integra radiator is still TWICE the size of a Civic single core radiator. Keep that in mind.
depending on your mounts and radiator choice you may have no choice but to run a pusher. I have Hasport mounts and a dual core PWR radiator. The clutch slave cylinder bleeder nipple is maybe 1" from the radiator.
chewiejdh
Jun 29, 2003 04:36 PM
