Fog light help!! 99-00 fogs on 91
So i have the fogs mounted behind the bumper right infront of the radiator and it looks pretty good and somewhat un noticable my question is do the oem fogs for a 91 civic plug into the fusebox at all?? if so where do they plug in? a pic of the fusebox layout would be sweet... thanks in advance
You can hook them up to the running or headlight lead wire under the dash. You will need a relay to accept the signal wire. GrounD the relay and then run a power wire from it to the sub-harness for the fogs. Then you have to ground the sub-harness.
If you don't understand, I'm sorry, that's the best way I can describe it. You may also try PMing Hondacivic90ed, he just installed a factory set with instructions, maybe he can scan them for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFstyle »</TD></TR><TR><TD CLASS="quote">so theres nowhere on the fuse box where you plug in fogs like an EK?</TD></TR></TABLE>
I could be wrong, but it didn't look like it when I went through it a few weeks ago. Again try PMing the member I listed above, I know he has the factory install instructions.
WAUKEENEM1
Mar 13, 2022 03:05 AM
Ef8crxsi4u2nv
19
May 13, 2010 01:55 PM
JDM CTR EK
Jun 13, 2003 09:51 PM
