JDM vs USDM Exhaust System
Old Jun 13, 2002 | 08:47 AM
98R-1144's Avatar
Default JDM vs USDM Exhaust System
I'm in the process of getting a JDM 4-1 header for my ITR. I've heard that the JDM ITR muffler is the exact same as the USDM ITR muffler.
I want to keep the car looking (and sounding) as OEM as possible. I plan to get the JDM 4-1 header, JDM cat, and JDM b-pipe. Will the JDM ITR b-pipe bolt on fine to the USDM ITR muffler? Theoretically it should since both JDM and USDM have the same muffler?
Also, will the US O2 sensor fit in this setup?
[Modified by 98R-1144, 9:49 AM 6/13/2002]
Old Jun 13, 2002 | 12:07 PM
01PYITR's Avatar
Default Re: JDM vs USDM Exhaust System (98R-1144)
I had heard that the JDM muffler is shorter, but is hearsay...
Come on peeps, someone has the answer.
well... TTT for ya
Old Jun 13, 2002 | 12:10 PM
Cosworth's Avatar
I don't think the USDM O2 sensor will work unless you weld in a O2-bung on the JDM cat. I think USDM comes with OBD2... JDM isn't OBD2, is it?
Old Jun 13, 2002 | 06:08 PM
98R-1144's Avatar
Default Re: JDM vs USDM Exhaust System (Cosworth)
i'm not sure..
come on someone has to know!
otherwise i'll end up getting the JDM 4-1 + high flo 2.5" cat..mated to stock bpipe
you think that will still yield good power, despite the bottleneck?
Old Jun 13, 2002 | 06:30 PM
Champ R's Avatar
Id actually like to know the same if a jdm 4-1 with 2.5" cat will yield little hp gains with the stock usdm exhaust.
Old Jun 13, 2002 | 07:57 PM
SPECR's Avatar
Default Re: JDM vs USDM Exhaust System (Champ R)
JDM b-pipe is has a slightly bigger diameter(close to 2.5) than the USDM. JDM is also about 4.5inches longer to accommidate the shorter JDM cat. In order to make it work w/ obd2, just have a muffler shop weld in the second bung for the 2nd o2 sensor. Assuming you are using JDM 4-1, JDM cat, JDM b-pipe, and USDM muffler.
Old Jun 13, 2002 | 08:16 PM
Reid's Avatar
Global Moderator
Default Re: JDM vs USDM Exhaust System (SPECR)
Please provide evidence to back this claim.
Thanks.
Old Jun 13, 2002 | 08:55 PM
Anderson's Avatar
Default Re: JDM vs USDM Exhaust System (Reid)
bump
Old Jun 14, 2002 | 05:27 AM
SurferX's Avatar
Tamotsu Horikoshi's article on the Type R in Japan states the exhaust is 57.2mm (2.25")
[Modified by SurferX, 7:33 AM 6/14/2002]
Old Jun 14, 2002 | 10:43 AM
98R-1144's Avatar
Default Re: JDM vs USDM Exhaust System (SurferX)
I think what he meant was the JDM B-PIPE is 2.5"..but the JDM muffler is the same as the USDM muffler (2.25").
Now would it be worth the price to get:
JDM 4-1 --> JDM Cat --> JDM B-PIPE --> JDM/USDM ITR Muffler
or just stick with my original planned setup:
JDM 4-1 --> High Flow 2.5" Cat --> tapered 2.5 to bolt on to USDM bpipe(?? I've seen them before..not sure who to get it from) --> USDM B-PIPE --> USDM ITR Muffler
Old Jun 14, 2002 | 10:48 AM
Jackson's Avatar
I have seen them both side by side, they are the same diameter. Jdm one is longer though.
Reid's Avatar
Global Moderator
Nope. Both are 2.25".
Old Jun 14, 2002 | 11:28 AM
98R-1144's Avatar
So the JDM cat essentially has a 2.5" inlet (from the header), but the outlet is 2.25 to mate w/the (longer) JDM b-pipe?
If that is the case, I would probably just get a high-flo 2.5" cat and find a tapered 2.25 end to ease the bottleneck into the bpipe.
Tommy_Gunns
Jan 14, 2019 05:14 AM
suesky
Jun 8, 2011 09:17 AM
brxtacy
Sep 10, 2009 01:45 PM
98R-1144
Jun 27, 2002 06:57 AM
