Acura 3.2 S Type
The plugs will cost you about $20 each and you will need 6 total. $30 for an air filter and another $30 for an oil change. Labor is 1hr for plugs 3/10 for filter and .5 for oil change. Most dealership will charge between $80-100 per hour labor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Datgurl_S_Type »</TD></TR><TR><TD CLASS="quote">I need to get a tune up...It would be my first tune up since I had the car. Does anyone know how much this might cost me? </TD></TR></TABLE>
Anyway back to the question first asked, you should be able to get a basic tune-up between $ 40 -100 depending on what filters,fluids,etc. that you change. Anyone should be able to do the very basics with a manual or walk-though of some sort. If not factor in those high labor costs.
you can get the plugs for about $12 each, but you really shouldn't need those until about 120k miles though.
things you should change though are:
Cabin filters
air filters
trans fluid or oil (depends if you have auto or stick)
brake fluid flush
coolant flush
ps fluid flush
Cabin filters
air filters
brake fluid flush
coolant flush
ps fluid flush
