maintenance for 2011 and beyond
Old Aug 20, 2007 | 05:47 AM
SwiftTypeR's Avatar
New User
Default maintenance for 2011 and beyond
I have a 01 itr with 57k miles. I plan on keeping this vehicle as long as possible. I've already changed the master clutch, slave cylinder and a o2 sensor. I plan on doing a timing belt, new valves/retainers, valve springs, camshafts, cam gears, clutch, flywheel and brake pads in a few months.
Is there anything else I should do? Should I do the water pump while I'm at it? I want to buy parts for my vehicle while I still can for another major tune up in 2011+, what do you think I should purchase?
Old Aug 20, 2007 | 09:57 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: maintenance for 2011 and beyond (SwiftTypeR)
Yes, do the water pump when you do the timing belt.
I would also consider replacing the cooling system hoses, at least the big ones. Good preventive maintenance.
Don't stock up on parts; some of them (e.g. ones made of rubber, rather than metal) don't have an indefinite shelf life.
Old Aug 20, 2007 | 10:05 AM
Todd00's Avatar
I said I don't want a title!
Default Re: maintenance for 2011 and beyond (nsxtasy)
I still have no problems buying OEM replacement parts for my 91 Civic Si. Honda has a good history about stocking replacement parts for their older models.
Now, GM, on the other hand...I would be quite scared after 10 years.
Old Aug 20, 2007 | 10:18 AM
SwiftTypeR's Avatar
New User
Ok, phew. I was worried Honda would stop making parts and I wouldn't be able to find them when something breaks. Looks like I don't have to stock up on parts, short term this is good for my wallet.
Old Aug 20, 2007 | 11:00 AM
Utilitarian's Avatar
Not to go too far off topic, but I was thinking about cosmetic parts that are available today on the CW models that may not be available much longer. Things along the lines of center caps, stickers, and "A" emblems.
Old Aug 20, 2007 | 12:59 PM
sp00led's Avatar
Wow, sounds like you have someone has some cash to blow. I think the timing belt is about the only maintenence I really would stress changing out of the above items you listed. I wouldn't stress it until 90k and you can change out your alt, ps, ac belts why you have them off.
I know some of you may think i'm crazy but I was like that to with my first usdm integra. Six hondas, 1 jdm itr, and a 500whp gsr later I really learned that if it ain't broke don't fix it.
I think you would be supprised to see how much of a beating a OEM honda part can take let alone on a close to stock car.
Old Aug 20, 2007 | 04:22 PM
polything's Avatar
57k miles? that s too early?
Old Aug 20, 2007 | 06:05 PM
SwiftTypeR's Avatar
New User
The vehicle is 7 years old. Wouldn't it be better to replace the timing belt etc now rather than wait till it breaks? When I mentioned camshafts, valves springs, retainers, valves, thats going to be aftermarket. I was thinking since I'm doing timing belt, why not change out the internals at the same time?
Old Aug 20, 2007 | 06:30 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (SwiftTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwiftTypeR &raquo;</TD></TR><TR><TD CLASS="quote">The vehicle is 7 years old.</TD></TR></TABLE>
A 2001 is six years old, not seven.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwiftTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Wouldn't it be better to replace the timing belt etc now rather than wait till it breaks?</TD></TR></TABLE>
Honda recommends replacing the timing belt after 105K miles or 7 years, whichever comes first. That doesn't mean you can't replace it sooner than that, but it means you can be reasonably confident that you can wait until then before replacing it, and it isn't likely to fail before then.
Old Aug 20, 2007 | 06:33 PM
sp00led's Avatar
I just thought the master/slave cyl were done early if they were not leaking. If you are swaping out the valvetrain for newer stiffer parts then that would make since. As for the timing belt it is a little early but won't hurt anything. The water pump, tensioner, and timing belt are done at the same time.
Old Aug 20, 2007 | 08:01 PM
ITR640's Avatar
Check your owners manuel for the maintance guide in the back.
I wouldn't worry about any of those internal parts. If you've taken good care of your car for 57k, I wouldn't those would need replacing.
Timing belt, and drive belts along with a water pump, tranny fluid, and a minor brake wervice (pads, fluid) are a good idea. Valve adjustment I think is in the 90k, along with plugs and all the seals. Those I wouldn't worry about, not at 57k.
It's a Honda, keep it clean
Old Aug 20, 2007 | 10:37 PM
SwiftTypeR's Avatar
New User
Default Re: (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Oh no you didnt.....
Purchased this itr on October of 00. Technically it's 6 years and 10 months old, that should qualify it as 7 years.
Old Aug 20, 2007 | 10:40 PM
SwiftTypeR's Avatar
New User
Default Re: (sp00led)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00led &raquo;</TD></TR><TR><TD CLASS="quote">I just thought the master/slave cyl were done early if they were not leaking. </TD></TR></TABLE>
They are, my master cylinder decided to give up one day while I was on my way home from work (hour drive). Wasn't fun I tried to keep it in one gear the whole time. The mc died so I replaced that + the slave cylinder. The o2 sensor died this year as well. Other than that, the car has been super reliable.
Old Aug 21, 2007 | 12:53 AM
JjuuN R's Avatar
Purchased this itr on October of 00. Technically it's 6 years and 10 months old, that should qualify it as 7 years. </TD></TR></TABLE>
So did I, what day did you purchase yours on?
fabioso
11
Jan 29, 2012 12:44 PM
mister_two
Oct 1, 2010 05:49 PM
Freshazzburu
Mar 1, 2007 07:37 AM
ih8danoles
Nov 14, 2002 07:59 PM
SleepinGSR
May 17, 2002 11:24 PM
