throttle body. flat head screw. adjusting question
Old Aug 19, 2007 | 10:18 PM
mustang5.slow's Avatar
* B A N N E D *
Default throttle body. flat head screw. adjusting question
how do i know if the screw on throttle body is at right position.??or when it is just right.???
HOW WILL IT AFFECT ME IF IT'S NOT SET RIGHT.???
and does that screw regulate??? thanks for the replies.
Old Aug 19, 2007 | 10:19 PM
Aralliius's Avatar
Default Re: throttle body. flat head screw. adjusting question (mustang5.slow)
when its just right the idle will be what u want it to be, if its not u will prolly stall out or waste ALOT of gass.
Old Aug 19, 2007 | 10:26 PM
* B A N N E D *
Default Re: throttle body. flat head screw. adjusting question (Aralliius)
wow. so there is no sure position.
I'm assuming this bes done when the car is cold??
Old Sep 6, 2007 | 11:05 AM
geebs's Avatar
yes there is a correct setting for the idle adjusting screw.. it should not be more than 3 and 1/2 turns unscrewed.. per the honda manual.. it should be set with the service connector jumped and at normal operating temp.. theres a certain rpm it should be at as well.. not sure exactly.. 750 +/- 50 for a manual i think..
tobytigger
May 27, 2015 08:11 PM
raverx3m
Apr 21, 2013 05:07 PM
magicguy
Jan 30, 2009 02:00 PM
twentytwocpb
Mar 20, 2008 10:47 AM
djmota
Jun 15, 2005 09:24 AM
