what can a tps do if set too high?
Old Aug 19, 2007 | 09:13 PM
emooheo's Avatar
Default what can a tps do if set too high?
What can a tps do if its set too high? My car has been idling funny and i just tested my tps and it says .7v at idle.. normal is ~.45. Could this be the solution to my idle problems?
Old Aug 19, 2007 | 09:16 PM
Syndacate's Avatar
Default Re: what can a tps do if set too high? (emooheo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emooheo &raquo;</TD></TR><TR><TD CLASS="quote">What can a tps do if its set too high? My car has been idling funny and i just tested my tps and it says .7v at idle.. normal is ~.45. Could this be the solution to my idle problems?</TD></TR></TABLE>
Yeah, that's weird.
I'm 99.9% sure it's supposed to be .5 completely off, and 4.5 completely on (WOT).
.7 isn't that far off from .5, I'm not sure if it would throw off the idle, but it could if it's fluctuating.
Old Aug 19, 2007 | 10:06 PM
mustang5.slow's Avatar
* B A N N E D *
Default Re: what can a tps do if set too high? (Syndacate)
how is the TPS even measured.?? and how is it adjusted??
Old Aug 19, 2007 | 10:08 PM
Syndacate's Avatar
Default Re: what can a tps do if set too high? (mustang5.slow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustang5.slow &raquo;</TD></TR><TR><TD CLASS="quote">how is the TPS even measured.?? and how is it adjusted??</TD></TR></TABLE>
It's a variable resistor.
I don't know how it's adjusted though.
Old Aug 19, 2007 | 10:29 PM
emooheo's Avatar
to measure it you need a voltmeter. cut a section of the red wire and probe it with the positive part of the meter, and the black to - on battery. turn keys on ignition on and numbers should pop up. to adjust you need to cut a slit with a dremel then move the tps around till you get .45 closed
Old Sep 3, 2007 | 05:43 PM
FowDow's Avatar
Default Re: (emooheo)
What if it stays at .30 volts even if you move it? HELP PLZ
Old Sep 3, 2007 | 05:45 PM
Syndacate's Avatar
Default Re: (FowDow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FowDow &raquo;</TD></TR><TR><TD CLASS="quote">What if it stays at .30 volts even if you move it? HELP PLZ </TD></TR></TABLE>
Then it's probably bad.
Old Sep 3, 2007 | 05:47 PM
2wheelhunter's Avatar
Default Re: (Syndacate)
when i put one on at the wrong tilt.. it was just a fuel cut at full throttle.. it would drive normally until WOT or just shy of it..
jardolei
May 13, 2008 04:50 PM
dc2gsr96
May 10, 2007 02:05 PM
meagainsttheworld
Sep 10, 2006 09:30 PM
go2sleep
Jun 15, 2006 08:54 PM
hatchfreak92
Oct 17, 2004 08:59 PM
