turbo 5th gen accords - do you think this downpipe will work??
http://cgi.ebay.com/ebaymotors...wItem
i am just wondering if this would work or be close on my setup. i have a 95 accord ex with the stock f22b1, rev hard manifold and t3/t04e. give me your input.. thanks
I dont think that would work without some modification... in which case you could have one probably built from scratch just as easily.
There is a cross beam that goes from front to back right about where that dp would go under the motor. Also I would think about the size difference in the motors/ chassis which that was designed and for which you want to use it... or consider the f series has an aggressive lean'd back mounting position in the bay that I do not believe a civic does.
