running on 3 cylinders =X
Take the spark plug out, and see if it's sparking...Next check and see if the cylinders getting fuel, switch the injectors and see if that's the problem. Thirdly, run a compression check on ur cylinders. That should at least tell u something.
d1D teh m4D vTAcH M15s yo?!
are you still drunk? just a pointer, when you type a "burn" story here that led to your ride getting fucked up, you'll probably get flamed
now go check your valves and do a compression test.
mn_babyboy
Aug 21, 2008 08:04 PM
