Clutch Assembly...help?
Old Jun 13, 2002 | 07:42 AM
dingusjt's Avatar
Default Clutch Assembly...help?
I just pulled an automatic tranny of an engine (d16z6) that i am swapping into my car, left over, i had a metal plate (like a washer) with the 6 mounting bolt holes in it, this was in between the torque converter and the mount on the engine block.
Now i am putting on a manual transmission and i need to know if the plate like washer with the 6 bolt holes in it, goes between the flywheel and engine block mount. (Just like between torque converter and mount). Someone help me out cause my Chilton manual doesn't show crap...
Old Jun 13, 2002 | 07:46 AM
2point6's Avatar
Default Re: Clutch Assembly...help? (dingusjt)
the washer is not used with the manual flywheel. You will have to get longer flyweel bolts however.
Alicali
Nov 21, 2016 07:49 AM
bsharp19
Mar 5, 2014 07:08 AM
MetalHead4454
Sep 12, 2005 01:38 AM
4ghett0child1
Jun 27, 2005 05:21 PM
