is my timing off?
Old Aug 19, 2007 | 04:16 PM
team703's Avatar
Default is my timing off?
yeah i tried to search but maybe didnt use the right keyword, ok well i have a 94 ls motor in a 94 civic, i started it up today and it wont rev past 3grand and i know i need a valve adjustment, but could my timing be off? The car starts and idles fine but like i said when i rev it , it doesnt seem to rev like my other ls did. what are the steps i should take?(compression check, get valves adjusted anything else...... and if my timing was off what would be the signs of forsure knowing?
Old Aug 19, 2007 | 04:22 PM
slowcivic2k's Avatar
Default Re: is my timing off? (team703)
You are in limp-home mode, what codes is the check engine light giving you?
Old Aug 19, 2007 | 04:33 PM
team703's Avatar
so what do i do reset my ecu to get out of limp mode
Old Aug 19, 2007 | 04:38 PM
No, you find out what caused it...
https://honda-tech.com/zerothread/1901557
Old Aug 19, 2007 | 04:40 PM
team703's Avatar
Default Re: is my timing off? (slowcivic2k)
ill get the code tomorrow and post it, thanks man hopefully ill have more info for you tomorrow
deezknuts
14
May 13, 2014 01:41 PM
Raymond94
Feb 28, 2012 06:04 AM
LostGsr
Aug 4, 2011 04:08 AM
TURBO+GSR+CRX=?
29
Feb 2, 2009 10:18 PM
4dek
Jul 6, 2008 10:51 AM
