problems from my swap.
i just got through with my zc swap....im having problems. as soon as i started the motor the check engine light came on. im using the d16a6 ecu. also my throttle response sucks badly. my timing is where it needs to be. i put an xtr stage 3 clutch, an f1 8 lb. flywheel, new axles, new l3 transmission, and i put the zc sohc non v-tec in to replace it. what should i do to help out this swap? thanx for the time.
thaiphob
Mar 12, 2003 06:49 AM
