2003 Honda Accord LX won't start
Old Aug 19, 2007 | 10:15 AM
reneejenk99's Avatar
Default 2003 Honda Accord LX won't start
I have a 2003 Honda Accord LX 4 cycle with 118,000 miles and it starts only when it wants to. I changed the battery. I also had the starter, alternator and compression check and reads that everthing is okay. Does anybody know what is going on? I check fuses and unit does have gas. Programmed ignition key for the immobilizer system is working properly. Somebody please help!
Modified by reneejenk99 at 7:59 PM 8/19/2007
Modified by reneejenk99 at 8:00 PM 8/19/2007
Old Aug 19, 2007 | 10:39 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2003 Honda Accord LX won't start (reneejenk99)
It may be a problem with the programmed ignition key for the immobilizer system.
Next time it happens, look for the following: When the key is inserted into the ignition switch, and turned to ON (II), the immobilizer system indicator on the instrument panel should go on for 2 seconds and go off.
If it goes on 2 seconds and keeps blinking, it may be a problem with the programmed key, or a problem with the immobilizer control unit-receiver. It will crank but will not start.
If the above does not happen, it could be something else.
Old Aug 19, 2007 | 11:14 AM
Default Re: 2003 Honda Accord LX won't start (tech8)
I tried this and the key goes off after 2 seconds. Any other suggestions?
Old Aug 19, 2007 | 12:43 PM
phootbag's Avatar
Got gas in it?
Old Aug 19, 2007 | 01:16 PM
djmixkikzazz's Avatar
try checkin all relays and fuses
Old Aug 19, 2007 | 01:25 PM
msedacca's Avatar
Default Re: (djmixkikzazz)
You can check the fuses underneath the driver side dash, just poke your head under there and open up the box and make sure everything is in there.
kv1
Honda Accord (2013 - 2015)
Aug 18, 2019 08:00 PM
Nick Effler
May 19, 2015 10:06 AM
mexicanswateam
Mar 18, 2010 11:03 PM
mellophonium
Nov 5, 2008 04:56 PM
Mx3Kfze
Dec 31, 2004 04:54 AM
