switching a k20a3 head with a k20a2 head
i was wondering if you could do a k20a3 nonvtec head and switch it with a k20a2 vtec head on a base model. would that be possible?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adrw1 »</TD></TR><TR><TD CLASS="quote">i was wondering if you could do a k20a3 nonvtec head and switch it with a k20a2 vtec head on a base model. would that be possible?
Possible: very
time consuming and money grubbing: very
</TD></TR></TABLE>Possible: very
Now that I found you on here again, I would like to respond to this little remark of yours "New baby - 02 ABP typeS: needs some TLC, looks like rice" NO **** SHERLOCK!!!! If I have to look at those Greek Tragedy of side skirts I am going to put a bomb in your car and do us both some justice so that disgrace of a S/C isn't sitting in front of our house anymore with those WINGS on it!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extremevtecracing »</TD></TR><TR><TD CLASS="quote">Now that I found you on here again, I would like to respond to this little remark of yours "New baby - 02 ABP typeS: needs some TLC, looks like rice" NO **** SHERLOCK!!!! If I have to look at those Greek Tragedy of side skirts I am going to put a bomb in your car and do us both some justice so that disgrace of a S/C isn't sitting in front of our house anymore with those WINGS on it!!!!!!!</TD></TR></TABLE>
WTF?
WTF?
And where is your turd car...oh wait.. last i checked it's still in San Antonio hoping to get "worked" on. I think the rust in the trunk will eat your car completely before you get your motor built and put back in. Hey my car drank a lot of red bull.. that's why the sideskirts HAVE WINGS!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5RickK20 »</TD></TR><TR><TD CLASS="quote">
WTF?</TD></TR></TABLE>
MIND YOUR BUSINESS!!!!
ANd CHris I must say...... TOUCHE!!!! Well played young man. Good follow through on your weak *** comeback.
Sorry to jack, but since the A3 has VTEC only on the intake and the A2 has VTEC for intake and exhaust, Would you need a Type-S ECU?
Sorry I'm noob at these still.
there was a whole deal about this on clubrsx.. it is possible to put an a2 head onto an a3 block but there is a lot of moddifying to get it to work correctly, it's time consuming and money spending. There's more to it then just slapping an a2 head onto a3 block and calling it a day. Personally i'd rather just fully build the A3 then trying to slap an a2 head onto a stock a3 and trying to make it work.
you dont even need to do all that. im building a a3 for my em2, you put stock type s cams and stock pistons in the em3 and you have a type s motor. that it ive done it and ive seen the results, the only diff between the two is the compression ratio of pistons and the non vtec exhaust cam on the a3. so spend like 500 on some cams and pistons n then go from there.
It's not that simple, you do need the head because your A3 head doesn't have the 3 lobes setup with the "wild" one in the center, so just having the cams won't do it. Also you do need the ECU because the A3 ECU activates the "VTEC-E" (switching from 12 to 16 valves operation mode) at 2200 RPMs on the A3, which is not what you need for a classic VTEC setup.
The difference between these heads has been covered before. This was a good thread about it: https://honda-tech.com/zerothread?id=2045625.
Look at the posted pictures so you can see the internal differences.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcivic1.7x »</TD></TR><TR><TD CLASS="quote">you dont even need to do all that. im building a a3 for my em2, you put stock type s cams and stock pistons in the em3 and you have a type s motor. that it ive done it and ive seen the results, the only diff between the two is the compression ratio of pistons and the non vtec exhaust cam on the a3. so spend like 500 on some cams and pistons n then go from there. </TD></TR></TABLE>
Shut ur poophole before some unsuspecting kid really wastes his money based on what u have said. there is the matter of the valve locking, the lack of oil squirters on the bottom end of the a3, and what the fack do the pistons have to do with an a3 head swap? youve done it? youve seen the results? ur full of ****!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIVIC 3 »</TD></TR><TR><TD CLASS="quote">
LMFAO.. this guy called you out and i agree with him.
</TD></TR></TABLE>LMFAO.. this guy called you out and i agree with him.
eg6cusco10pt
Jun 11, 2004 12:41 PM
