CRX Code 63
Old Aug 18, 2007 | 10:27 PM
specificcivic's Avatar
Default CRX Code 63
I have already discovered that a code 63 = Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response. However, I thought that stock 90 CRX Si's only had 1 O2 sensor. Which brings me to my question: How can a car which doesnt have a secondary O2 sensor throw a code 63?
some facts about my CRX:
-it has been parked for 3.5yrs now but was started for the 1st time on wed night since being pk'ed.
-since it was parked, it had about 1/8 tank of gas in it for the 3.5yrs. I did drain this gas out when I replaced the FP.
-i just replaced the dizzy, alt, Fuel Pump, cap/rotor, plugs, and plug wires.
-The CRX does have a huge hole in the axle-back pipe on the exhaust.
-B4 I changed the oil on the vehicle, I ran a Seafoam treatment in the crankcase and gas tank w/ new 89 octane gas.
PLS help
Old Aug 18, 2007 | 11:31 PM
garageEF's Avatar
Default Re: CRX Code 63 (specificcivic)
you need to verify the code.....this doesnt make much sense
Old Aug 18, 2007 | 11:52 PM
Default Re: CRX Code 63 (garageEF)
it didnt to me either but I might be reading the code wrong. Just in case, I shot a vid of the ECU. here u go:
http://video.tinypic.com/player.php?v=4t6avj7
Old Aug 19, 2007 | 12:33 AM
crx_si-r's Avatar
i dont kno where ur gettin code 63, but im reading it as a code 9. cylinder no. 1 position.
Old Aug 19, 2007 | 12:56 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specificcivic &raquo;</TD></TR><TR><TD CLASS="quote"> How can a car which doesnt have a secondary O2 sensor throw a code 63?</TD></TR></TABLE>
If your getting a code 63, your not running the stock ecu then. Does not matter what car you run, it matters what the ecu looks for.
Old Aug 19, 2007 | 01:21 AM
Default Re: CRX Code 63 (crx_si-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_si-r &raquo;</TD></TR><TR><TD CLASS="quote">i dont kno where ur gettin code 63, but im reading it as a code 9. cylinder no. 1 position. </TD></TR></TABLE>
sorry I am used to OBD2 on my EK. it looked like 6 long blinks and then 3 short blinks. however, this makes 5 people proclaiming it as code 9 so I am gonna go w/ it. My friend was saying that it usually means that I need a new dizzy, is this corect?
Old Aug 19, 2007 | 09:24 AM
hondacivic90zc's Avatar
i would personally just buy a new dizzy and be done with it or if you or somebody you know has a spare dizzy try that out first just to make sure
Old Aug 19, 2007 | 10:21 AM
it looked like 6 long blinks and then 3 short blinks. however, this makes 5 people proclaiming it as code 9 so I am gonna go w/ it. My friend was saying that it usually means that I need a new dizzy, is this corect?</TD></TR></TABLE>
6 long blinks = 60
3 short blinks = 3
Code 63.
Old Aug 19, 2007 | 10:30 AM
ohfosho's Avatar
but it's not an obd2 ecu it's an obd0. i would guess it's nine since it's obd0 and it wont start.
does it start and then shut off? or just not start?
Old Aug 19, 2007 | 10:35 AM
Default Re: (ohfosho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohfosho &raquo;</TD></TR><TR><TD CLASS="quote">but it's not an obd2 ecu it's an obd0. i would guess it's nine since it's obd0 and it wont start.
does it start and then shut off? or just not start?</TD></TR></TABLE>
I didn't see the video till now, its code 9
Old Aug 19, 2007 | 10:54 AM
funny u ask...it runs normally
93grayeg
10
Oct 17, 2011 08:07 PM
ZC DOHC CRX
May 8, 2010 07:40 PM
white90rexsi
25
Sep 2, 2007 05:16 PM
MIZIKETSK
Jul 3, 2004 11:31 PM
