Putting in A/C, what all do I need?
Old Aug 18, 2007 | 09:09 PM
trustnoone5656's Avatar
Default Putting in A/C, what all do I need?
Just bought a new sanden to replace my dead one and I need to know what else I will need. Car hasn't had functioning a/c in 4 years. I've been told I'll need a new drier and gaskets. Pretty sure my condenser is all right. Will I need anything else? Thank you
Old Aug 19, 2007 | 06:15 AM
Cory man's Avatar
Default Re: Putting in A/C, what all do I need? (trustnoone5656)
Definitely replace the receiver/dryer and inspect all o rings. You might as well replace the orings at the high and low side lines to the compressor since they will be removed. The entire system will need to be vacuumed w/ an a/c machine since air will be present once the lines are removed. Charge it and you should be good.
Old Aug 19, 2007 | 08:39 AM
Default Re: Putting in A/C, what all do I need? (Cory man)
That sounds good. Thanks for your reply
