Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
what kind of bulbs can I use?
Old Aug 18, 2007 | 07:03 PM
kcari's Avatar
Default what kind of bulbs can I use?
Is there a specific HID bulb I can use to replace cheap projector bulbs?
Or can I take factory OEM bulbs and put them in projector slots?
civic 01 coupe
Old Aug 18, 2007 | 07:57 PM
1llmatic's Avatar
New User
Default Re: what kind of bulbs can I use? (kcari)
each projector headlight has a different bulb size...normally either h1 h3 for the 7thgen projectors.
There are HID kits for every bulb size.
OEM headlight Bulbs are not the same size as the projector headlight bulbs.
Old Aug 18, 2007 | 08:10 PM
kcari's Avatar
Default Re: what kind of bulbs can I use? (1llmatic)
so whats the best way of knowing what to replace the projector bulbs? Does it list or someplace on the bulb or whatever? and can I get bulbs that are not HID - will those still be bright as close to OEM or more? I just heard projector bulbs that you get from ebay suck... so...
Old Aug 18, 2007 | 08:26 PM
1llmatic's Avatar
New User
OEM headlights are brighter than regular bulbs or 'superwhite' bulbs for projectors.
if your projectors came with bulbs then yes there are regular bulbs available.
projectors are not bright unless you use an HID system.
Old Aug 19, 2007 | 09:52 AM
kcari's Avatar
ic ic
that clears up a lot for me.
How would I figure out what size bulbs would fit into my projector?
Do HIDs last a long time? Would they be so bright that it would blind other drivers?
NY's_Freshest
Lighting
Jan 28, 2012 02:24 PM
Blacklabel182
Jun 12, 2007 01:39 PM
Sir_CCord
Dec 4, 2006 03:34 AM
JforJonathan
Mar 13, 2004 01:10 PM
shauniewalnuts
16
Sep 17, 2003 09:09 AM
