Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
changing my tranny fluid and im wiggin out
Old Aug 18, 2007 | 06:52 PM
i-VTEC_DOHC's Avatar
Default changing my tranny fluid and im wiggin out
the dealer told me that bolt to drain the tranny fluid is bolt 14... but i think its 9. so wtf... cuz it really doesnt make sense to me as to why the fill bolt would be lower then then drain.. makes sense?? if someone can give me a for sure answer it would be greatly appreciated
</a>
Old Aug 18, 2007 | 07:10 PM
not to be mean or anything but can somebody plz tell me if the dealer is right or am i right?? and its gettin kinda late..... so plz help!
Old Aug 18, 2007 | 07:11 PM
midwest aaron's Avatar
Default Re: changing my tranny fluid and im wiggin out (i-VTEC_DOHC)
14 is the fill hole and 9 is the drain bolt
Old Aug 19, 2007 | 05:25 AM
toyomatt84's Avatar
Sanji
Default Re: changing my tranny fluid and im wiggin out (midwest aaron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midwest aaron &raquo;</TD></TR><TR><TD CLASS="quote">14 is the fill hole and 9 is the drain bolt</TD></TR></TABLE>
That is correct.
Old Aug 19, 2007 | 07:27 AM
phootbag's Avatar
Default Re: changing my tranny fluid and im wiggin out (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
That is correct.</TD></TR></TABLE>
That is correct.
Old May 30, 2012 | 03:27 PM
ourbloodykisses's Avatar
can anyone get that image or photos back?
need to be sure on exact locations. on the fill and drain bolt
replaced an axle and fluid came out. Im guessing this is trans fluid, not gear oil/diff oil?
Old May 30, 2012 | 08:17 PM
toyomatt84's Avatar
Sanji
You always want to drain your transmission fluid when you do an axle pull. The axles seal in fluid.
As for the bolt locations, this DIY is pretty much identical to that of the D17 transmission:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/default-%5Bfaq%5D-how-change-your-civic-manual-transmission-fluid-1687986/
Old May 31, 2012 | 12:36 PM
thanks, perfect matt, thank you. wasnt 100% on it.
Old May 31, 2012 | 02:51 PM
toyomatt84's Avatar
Sanji
No problem, bud. Its a fairly simple process... but one that needs to be done.
Old May 31, 2012 | 03:48 PM
the fill bolt is quite sneaky unless you are really under there looking, ahha
G2_Fella
Oct 10, 2008 04:43 PM
91tegra07
Mar 11, 2008 03:24 PM
pocketviper
Jun 3, 2007 12:40 PM
Damon Reeves
Apr 15, 2007 09:11 AM
Slammd Sol
Mar 28, 2004 10:21 AM
