removed sunroof wiring, now the wipers dont work.
Old Aug 18, 2007 | 05:27 PM
GSRCRXsi's Avatar
Default removed sunroof wiring, now the wipers dont work.
ok well i removed the sunroof wiring because im putting in a plug. well after i did this, the wipers/washers no longer work. checked the fuse. its good. and ive spent hours staring at the wiring diagrams in the helms and im not seeing any connection. they do share a common ground, but its through the fuse box and i didnt remove any ground connections on the chassis. helms shows them all comming into the fusebox and going out to the common ground. has anyone had this problem? any help is much appreciated.
Old Aug 19, 2007 | 03:44 PM
GSRCRXsi's Avatar
Default Re: removed sunroof wiring, now the wipers dont work. (GSRCRXsi)
no one has had this problem? has anyone ever removed the sunroof or its wiring?
Old Aug 19, 2007 | 06:10 PM
Crx Jimmy's Avatar
I removed the sunroof for a plug but didnt touch the wiring. How much could it weigh 1lb? good luck
Old Aug 20, 2007 | 06:17 AM
GSRCRXsi's Avatar
Default Re: removed sunroof wiring, now the wipers dont work. (Crx Jimmy)
i took it out more to make it look a little cleaner. my whole interior is stripped so i wanted to remove that wire as well. i dont have the interior covering it up anymore
Old Aug 25, 2007 | 03:31 PM
GSRCRXsi's Avatar
well after about an hour of tinkering with a multimeter, i traced the problem to the fuse box. i wasnt getting any voltage through it on the fuses for the components that werent working. initially i thought it was the fuse box itself, but when pulling it out for inspection i noticed that one of the connectors on the rear was only half plugged in, jackpot! plugged it in all the way and viola! all my electrical problems were fixed. blinkers, hazards, wipers, washers, and right low beam headlight all fixed.
Old Aug 25, 2007 | 07:20 PM
Crx Jimmy's Avatar
EdiEG
Mar 11, 2015 05:07 AM
crxnonvtec
Apr 10, 2008 07:29 AM
