alternator is done but lights still there
Old Aug 18, 2007 | 04:25 PM
ezol's Avatar
Default alternator is done but lights still there
just got my alternator done today but my battery light, e-break light , the door adjar lights, and the break lamp bulb light come on randomly. the charge on the batery while car on is 13.9V. is it a bad alternator or is it some other electrical problem.
thanks to all that hepled.
Old Aug 18, 2007 | 05:02 PM
phootbag's Avatar
Default Re: alternator is done but lights still there (ezol)
sounds like a bad connection, or a slipping belt assuming the new alt is any good
Old Aug 18, 2007 | 06:25 PM
ddg2sailor's Avatar
What year?
If the battery is holding a charge then it might be a problem with the diagnosic panel. In my old 93 accord I keep getting a light saying I have a bad brake light (I dont) and it normaly clears after a restart.
If your alt is at 13.9 that should be enough to run everything....
Are your headlights flashing as you drive? If so look for a bad engine to chassis ground strap.
Old Aug 18, 2007 | 10:42 PM
ezol's Avatar
my headlights dont flash when im driving but it does flash when i push to roll down or up my windowes.
Old Aug 19, 2007 | 04:22 AM
JDM_DC4_Fanatic's Avatar
I would check your connections for corrosion. When the car is running the car should put out 14.4v
Modified by JDM_DC4_Fanatic at 7:54 AM 8/19/2007
Old Aug 19, 2007 | 09:26 AM
BLKFLSH's Avatar
Get your battery and charging system checked by Autozone (or some other parts store) using a machine tester (prefferably bear). When my battery was going dead it still showed plenty of voltage on a multimeter (over 14), so I would not go by that reading. CCA (Cold Cranking Amps) are what's most important. Good luck finding the problem.
khmr270
Oct 31, 2022 01:01 PM
le0ftw
Jun 9, 2009 09:33 PM
rclark
Jan 8, 2009 07:49 AM
bard329
Jun 20, 2006 07:46 PM
pwalk
Sep 20, 2004 09:35 PM
