valve springs and retainers sizes???
Not quite sure what size valve springs and retainers i need to get. Shopping on ebay and i've bid on a set of 7%steel 11/32" valve stem and 1.430"to 1.500" dual or single spring retainers made by comp cams. Thinkin about biddin on a set of valve springs that are 1.800 in height installed and checking height spring diameter is 1.450 and seat pressure is 110lbs. Is this the right set for my car. H22 engine. If not, what size do i need?
why are you bidding on things that you dont know if they will work?
why not buy valvetrain that you know works? supertech? skunk2? brian crower? eibach? rocket motorsports?
eibach springs and crower steel retainers here
mkw1
Mar 8, 2008 04:43 PM
BoBo Racing
Mar 22, 2006 05:47 PM
