Bogging down
Old Aug 18, 2007 | 01:53 PM
CivicSi2032's Avatar
Default Bogging down
i was driving my 2000 civic ex with poorman's swap and when i woould down shift and open it up its like the throttle would just cut out and start bogging down with no acceleration but when i drive it slow and accelerate its fine. can anybody help me out on this? its pissing me off that i cant accelerate fast! thanks
Old Aug 18, 2007 | 02:30 PM
spoon_concept_eg6's Avatar
Default Re: Bogging down (CivicSi2032)
i have an ls/vtec swap. reffering to a poor mans swap, im guessing that your running and ls/vtec swap also. what kind of timming belt are you running? also what kind of water pump? is it a GS-R water pump? or is it the stock LS water pump?
the timming on these hybrid motors can be really tricky to get right. for me i never mess with timing. it leave that to the shops. it only costs 80 bucks or so to get the timming set right, and thats not just shooting the timming. you have to do the whole thing. take off and align and put back together. make sure the cams are set to zero degrees again.
i had my fair share of mistakes and at times my car was bogging like yours too. so becareful, dont push your car till you have the timming right, or you can kiss your valves good bye.
Old Aug 18, 2007 | 02:39 PM
BlackoutVTi's Avatar
Default Re: Bogging down (spoon_concept_eg6)
To add a more general note: I've had experiences with a similar problem to your own, and it's been suggested that my TPS is acting up. Maybe yours is as well. If you run out of ideas, you could always check that.
theslugbug
May 30, 2008 03:34 AM
GsrTurboCRX88
Jun 5, 2006 07:44 AM
MiKeAhOwSkI
Dec 30, 2004 04:02 AM
1slowcrx
Nov 17, 2004 03:24 PM
spettinger
Feb 1, 2003 12:49 PM
