omni power springs with oem retainers??
Want to know if I can use the oem retainers with omni power valve springs?? I have looked around and have found nothing saying that I can not but just want to see what others say..
i would not do this cause omni-power springs and retainers are made to have a snap fit design that stops the premature wearing springs and retainers. it does so cause it prevents movent of the retainer in the springs.
you can use your stock retainers and your stock valves.. oem retainers are steel which means they will not wear as much as aftermarket.. they are heavier and most want to replace them for that reason.. if youre short on funds you can use oem..
shawn
shawn
bigsubs
Oct 15, 2006 07:20 AM
DelSolDon
Oct 5, 2005 04:58 PM
