Need Swap Wiring HElp
Ive been researching and reading bc this will be my first swap. I have a 95 gsr swap that i am wanting to swap into my 1993 EG. if i use the gsr harness ecu and hondata wich has the knock sensor disabled other than vtec what else will i have to wire?
ive found this but every were else ive only heard about having to wire vtec?
VTEC Solenoid Yellow/Green A4
VTEC Oil Pressure Sensor Blue D6
VTEC Ground Black Chassis Ground
Knock Sensor Red/Blue D3
Evap Purge Power Yellow/Black 12V Power
Evap Purge Solenoid Red A20
Secondary Intake Solenoid (IAB) Pink/Blue A17
Also how do i wire the 4 wire o2 sensor any diagrams would be apprecated ive searched and searched i just need some guidance. thanks
b16egva
Feb 27, 2006 04:41 PM
Cynical 1
Sep 23, 2002 04:41 PM
