Blox comp type C's cam settings
Old Aug 18, 2007 | 01:29 AM
Mostecstreethb's Avatar
Default Blox comp type C's cam settings
I lost my spec sheet and box do have one posted but i was woundering what the inital seting is for the cam gears and fuel psi I think it was 2+ in and 5psi+ but does anyone know for sure and does any one know a good etting is for them Thanx and please no smart coments Im just looking for a lil help
Old Aug 18, 2007 | 02:32 AM
dannylDAsport's Avatar
Default Re: Blox comp type C's cam settings (Mostecstreethb)
0, 0 stock till u get tune
Old Aug 18, 2007 | 02:54 PM
Default Re: Blox comp type C's cam settings (dannylDAsport)
0-0 isent right when you have a big cam the start up setting needs to be advanced and Fuel PSI bump. If you dont have the cam degreeing right the duration on the cam will cause the int and Ex valve clip each othe thats why when you buy the cams it comes with a spec sheet with the settings on it. I just lost mine and I forgot the settings. Im not dumb I know engine building and tuning dont get confused im just forgetfull. But you are right about one thing to get the car tuned but the settings are wrong you need to set the cams right then go get it tuned to advance it anymore Thanks though
Old Aug 18, 2007 | 03:05 PM
00Red_SiR's Avatar
All Motor Mentor
What kind of tuning are you using (hondata/Crome etc)? Also you're running the Jun 3 copies which have pretty close to, if not stock sized primaries if memory serves correctly. That means that those cams aren't so big that you'd have the valves "clipping" each other if set at 0'-0'. Stay out of Vtec until you get it tuned. Bumping fuel pressure is recomended on the cam card? If that's the only tuning you are using, that car will run pretty rich especially in the lower rpm range.
Hdeucedeuce
18
Mar 21, 2012 03:47 PM
hybrid2007
Apr 11, 2008 03:12 PM
dohc_profile
Feb 14, 2007 12:37 PM
hybridnorth
Jul 14, 2005 10:51 PM
Redsun
Aug 30, 2004 06:23 AM
