ECT Gauge Problem (no reading)
ok so.... i just noticed today that my ect gauge is reading zero (wierd i know). Anyways upon driving i then noticed it started to twitch a little. It then went to a normal looking reading, then went to cold again. Upon thinking it was the sensor, i took a quick datalog snapshot of the temp. All looked fine. FYI i have put a gsr cluster in my eg. with this in mind i thought maybe one of my wires went funky. pulled out the cluster unwrapped all wires to check my soldering job. all looked fine. Now, i put everything back in and still nothing. Any info you guys could give me would be much appriciated.
Check the coolant temp sensor on the side of the block, its a little nipple connector with a rubber boot over it, similar to the oil pressure switch only smaller, this sensor feeds the cluster. It is right below the distributor.
There is a sensor for the ECU, and one for the cluster, for what reason I don't know, but there are two on the head, the other is a two pin connector right under the vtak solenoid.
CRX-CHACE
Jun 30, 2013 02:45 PM
Pablo Escobar
May 15, 2006 07:49 PM
