how do i know when my alternator is gone.
Old Aug 17, 2007 | 08:42 PM
ezol's Avatar
Default how do i know when my alternator is gone.
while i was driving my battery light, e-break light , the door adjar lights, and the break lamp bulb light. all these turned on(in the dash), but the car was still going i pulled over to see what was wrong and couldn’t find anything but i did notice a humming noise near the timing belt and the alternator side. i put a volt meter on the battery and the reading was 12.1V (with the car off) and 11.8 (with the car on ) 11.5 with the lights turned on and the fan on) is it just the battery? does anyone have any ideas about this.
thanks to all that have read this post and the help.
Old Aug 17, 2007 | 08:47 PM
accord478's Avatar
Default Re: how do i know when my alternator is gone. (ezol)
its the alternater not chargin ur battery if im right but prob not but i think it is bc i use to have jeep with 41/2lift and i did a lot of georgia red clay mud biggin (i miss that jeep) and one day me and some friends were having fun and alsudn i heard weard high pitch type of noise. and i didnt think nothing of it and i was on the way back home all my abs lights bettery lights and all that came on and i had hard time driving and thing was the bearing on my alternater was shatterd my mud and it went capump ( died) so i had to replace it.... do u have any charge at all on the battery when u drive ur car ???
Old Aug 17, 2007 | 08:54 PM
ezol's Avatar
the car is still drivable. i dont know if im losing charge or not . everything still works
Old Aug 17, 2007 | 09:38 PM
bseriescrxsi's Avatar
your alternator is gone...your running straight off battery and it wont last long, with the alternator running right the meter should read 14.4-14.5
Old Aug 17, 2007 | 11:19 PM
ezol's Avatar
if my alternator is gone what brand should i buy
NSA Alternator - Delco CS130D Alternator; Amps: 105
USA Industries Alternator
Orange County Alternator Alternator
Bosch Alternator
Denso Alternator
Aftermarket Alternator - All (Delco Remy) (105 Amps)
or should i get a oem honda one or if some one has any other ones that are good.
thanks
Old Aug 18, 2007 | 06:57 AM
zumer2007's Avatar
Check for the warranty offered for each, and go with the ones that offer a limited lifetime warranty. (Some aftermarket parts are only warranted for one-year, which I don't feel is sufficient for an alternator.) If you feel more comfortable with name-brand parts, then go with the Denso, Bosch, or Delco. If you have (or plan to add) an amplifier to your audio system or high-wattage lighting, then choose one of the higher-amperage alternators. Otherwise, something that matches the power of your stock unit should be fine.
I try to stay away from parts that only offer one-year warranties because I live where the temperature can vary from below-freezing to the 100's. The temperature variation puts a lot of stress on components. When I would use cheap parts, I used to always have something fail on me on the first over-90-degree day of the year! The alternator is unique in that it contains mechanical, electrical, and electronic parts (e.g. bearings, coil windings, and the voltage regulator). There's a lot of things that can wear out or fail, so you want to select a part that the manufacturer will stand behind. This is especially true since you'll probably be spending about $150 for it. One car I have needed the alternator replaced three times before I got one that lasted! The lifetime warranty saved me a *lot* of money.
stocker2shocker91
Nov 11, 2015 05:02 PM
homero
Apr 4, 2012 10:39 AM
firefighter509
Acura TL, RL & ZDX
Sep 28, 2011 02:36 PM
Ithinkyourlost
Nov 19, 2006 09:21 AM
JokerTypeR
29
May 14, 2005 01:52 PM
