DC2R damper height vs EF(8) damper height??
Just wondering the difference in the damper height between DC2R and EF8?
is it ok to run the nuespeed koni's that are 20mm shorter for DC2R... on an EF8?
anyone running a similar setup?
i dont want my crx to be dumped super low (like no guard scraping) but low is fine.
EF shock bodies are 18mm shorter than a EG/DC...so you will basically have stock travel when you transfer them to an EF (you need EG/DC forks to do this) the rears are the same as far as i remember.
DA9 Integra
14
May 11, 2006 01:41 PM
