how much mileage is too much for boost
Old Aug 17, 2007 | 05:56 PM
808jdm_profileEG6's Avatar
Default how much mileage is too much for boost
So I have a gsr turbo set up 125k on the motor and I boosted it 3k ago.if my car is tuned how much longer could it last? Im running 5psi now ans will be running 9-10psi...The motor seems very healty.and was doing 14.7 all motor stock before the kit went on.
Old Aug 17, 2007 | 06:15 PM
quicksilver1689's Avatar
i ♥ snails
do a leakdown test that will tell you the condition of the rings and if your leaking past the valves. Have you ever found metal shavings in your oil?
Old Aug 17, 2007 | 06:50 PM
ef9civicgen4's Avatar
I've seen a stock 91 ls get boosted with 190k on it, still the original never rebuilt motor. drive boosted for over 2 years @9psi, even with 230k on the odometer. then just last month, removed the kit, replaced the AC, and now drives it as a dd without any problems what so ever.
some motors are just better then others. use what resources you have to find the internal condition of your motor. obviously check for any kind of smoking or burning of oil. if everything seems up to par, drive it til a problem develops and go from there.
Old Aug 17, 2007 | 07:07 PM
integraRS-T's Avatar
Default Re: how much mileage is too much for boost (808jdm_profileEG6)
i got 167k on my rs did a compresion test and got 190psi on all pistons thats healthy as hell bosting soon at 8-10psi
Old Aug 18, 2007 | 10:29 AM
stealthmode62's Avatar
Default Re: how much mileage is too much for boost (integraRS-T)
225k stock LS, 11psi with a basemap. Compression good= game on.
Old Aug 18, 2007 | 03:09 PM
posHonda's Avatar
i have 142k miles on my b18c1 currently and hopefully will be boosted by 160k lol
Old Aug 18, 2007 | 04:29 PM
spets's Avatar
I'm boosted at 135k.. now 146k and no issues.
Old Aug 18, 2007 | 04:58 PM
red civic standard's Avatar
Default Re: (spets)
boosted the stock motor in my wagon at 185k.
still running good at 221k
Old Aug 19, 2007 | 10:56 AM
Wopsicle69's Avatar
Default Re: (red civic standard)
Ive got over 420,000km on my LS block. It Started out as a stock 400,000km LS motor which i kicked the crap out of for like 5000km. Came across a turbo kit, freshend the head, cometic headgasket, arp's. Ran 8psi untuned (FMU) for like 5500km with no problems. Got a b16 head, used the same headgasket, same block (now at 411000km), fresh arp's and a bunch of new turbo parts. I experimented with different turbos and boost levels, timing, fuel etc for a long time. I think the most amount of boost I ran on was 15psi, but not for too long. AND NOW, finally 420,000km later if spun a bearing. All details of the motor are in the sig. LS's are some proper ****.
Dreamw3rkz
Oct 24, 2008 06:02 PM
2000GSRT
Mar 9, 2005 10:49 AM
Curturbo
Dec 28, 2004 08:59 AM
DeL SLo
Jan 11, 2003 11:43 AM
