need help
Old Aug 17, 2007 | 03:45 PM
thesoundofturbo's Avatar
Default need help
well i got done swapping my motor in and it was my first time.
my car turns over but no start im throwing a code 10 could this stop me from my engine starting?oh yeah i swapped in a y8 and stayed obd0
i also found these 2 wires on the drivers side engine harness dont kno where it would go.there yellow with a black strip one wire is more fatter then the other also
Old Aug 18, 2007 | 08:37 PM
Default Re: need help (thesoundofturbo)
any1?
Old Aug 18, 2007 | 08:43 PM
garageEF's Avatar
did you convert to mpfi?...those are supposed to be soldered together then run to the resistor box.
Old Aug 18, 2007 | 08:53 PM
Default Re: need help (garageEF)
your sure? cause my resister harness isnt cut for anything?or am i supposed to wire it sumwhere else?its my first time on doing a swap so bare with me haha
Old Aug 18, 2007 | 09:06 PM
garageEF's Avatar
was your car dpfi before? what engine harness are you using?
Old Aug 18, 2007 | 09:10 PM
my car shouldbe mpfi already since i had a running si a6 motor in it before running and im guessing its a si harness.and theres 4 wires komming from the ecu to the wire harness
stevieturbos
Jan 6, 2010 05:37 AM
94allmotor
16
Oct 27, 2009 03:55 AM
89sicivic
Jan 3, 2008 07:07 PM
