**Accu-Turn 1450 Tire - Wheel Balancer** Excellent condition!
The Accu-turn 1450 tire wheel balancer has multiple operator capability, allowing 2 operators to work on the balancer at the same time, without loss of wheel parameters. 2D Semi-automatic parameter entry, 2 of 3 parameters are entered automatically. 4 balancing modes including PAX balance mode, tire matching, and hidden spoke mode. Hidden Spoke program calculates weight amount so that weights can be applied behind the wheel spokes for the most aesthetically pleasing tire and wheel balance job. Truck round-off mode to ensure proper balancing of light truck and SUV tires and wheels. 2 brake systems feature automatic brake after spin, as well as, foot activated spindle lock to guarantee accurate weight placement. 6 second balance cycle time. 17 weight storage bins with on-balancer cone storage.
accu-turn 1450 wheel balancer
Features of the 1450 Tire - Wheel Balancer:
* Multiple Operators (2)
* Distance arm holds weight (Accu-stik)
* Stop at top outside of plane
* 4 balancing modes - ALU
* Hidden spoke mode
* Static and dynamic balancing modes
* Match balance mode
* PAX balance mode
* Truck round-off mode
* Automatic brake after spin
* Inch / Millimeter toggle
* Auto recalculation with changed parameter
* Minimization of static unbalance
* Self-diagnosis
* Display screen saver
* Quick nut centering device
* 3 cone system
* Wheel hood
* Spindle lock – foot activated
* Weight pliers, Width calipers
* Rim width capacity 1.5” - 20”
* Tire width capacity 21”
* Rim diameter capacity 10” - 30”
* Tire diameter capacity 42”
* Max. wheel weight 165 lbs.
* Accuracy .5 gram
* Cycle time 6 sec.
* Cabinet width ( to end of hood ) 47.5”
* Cabinet depth ( with hood ) 56”
* Cabinet height ( to top of display ) 44.5”
* Motor 1 H.P.
* Electrical requirements 110 volts
* Weight 308 lbs.
Used for only 2 years. Excellent working condition and makes balancing tires an easy job. My asking price is $2500.00 obo. NO LOWBALL OFFERS as you know this machine retails for well over $3500.00 brand new. Let me know if you're interested by calling me directly at (510) 304-3216. Thank you!
* Hidden spoke mode
* PAX balance mode
* Self-diagnosis
* 3 cone system
* Wheel hood
* Accuracy .5 gram
* Cycle time 6 sec.
* Motor 1 H.P.
* Weight 308 lbs.
