H22 Skunk2 Pro-Series Cams with Type-S Pistons (11:1) compression
Old Aug 17, 2007 | 08:46 AM
Import RP's Avatar
Default H22 Skunk2 Pro-Series Cams with Type-S Pistons (11:1) compression
Have any of you running Type-S pistons ran the Skunk2 Pro Series Pro1 or Pro2 cams yet? Interested in your results...particularly how the Pro2 cams would fair with 11:1 compression.
Old Aug 17, 2007 | 09:24 AM
h22crxpwr's Avatar
Default Re: H22 Skunk2 Pro-Series Cams with Type-S Pistons (11:1) compression (Import RP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import RP &raquo;</TD></TR><TR><TD CLASS="quote">Have any of you running Type-S pistons ran the Skunk2 Pro Series Pro1 or Pro2 cams yet? Interested in your results...particularly how the Pro2 cams would fair with 11:1 compression.</TD></TR></TABLE>
pro 1's on stock jdm h22 dyno'd 210 whp tuned with crome....
pro 2's on stock jdm h22. dyno'd 180 after the same engine with stock cams dyno'd at 191. a loss of 11 hp with the pro 2's on a stock jdm H22 tuned with crome.
both cars run on the same dyno with the same tuner...... pro 2's on stock motor
pro 1's on stock motor
Old Aug 17, 2007 | 09:30 AM
h22crxpwr's Avatar
Default Re: H22 Skunk2 Pro-Series Cams with Type-S Pistons (h22crxpwr)
i saw in your other post that you were going with pro 2's. i'd say to run pro 1's instead. i've seen the power loss with pro 2's on a mildly modded motor. you need a lot more compression to run those cams.
Old Aug 17, 2007 | 10:03 AM
GoldLudeRay's Avatar
what about the tunner stg2 skunk cams on a stock motor
Old Aug 17, 2007 | 10:38 AM
h22crxpwr's Avatar
Default Re: (GoldLudeRay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldLudeRay &raquo;</TD></TR><TR><TD CLASS="quote">what about the tunner stg2 skunk cams on a stock motor</TD></TR></TABLE>
I ran the regular stage 2's with no prob on a stock motor with great gains. but pro 2's no way...
Old Aug 17, 2007 | 10:55 AM
H22Accord210's Avatar
i have a stock bottom end on my h22a and i have pro series stage2 on my head and its has a basic street tune with crome and i am very unhappy with the results it almost feels as if i lost power rather than gain over my stock cams, i have the degrees set up as (3+ on the intake 4+on the exhaust) thats what the tuner said will work but i must say it sux so far. Im going to the dyno pretty soon hopefully they can tune it better than what it is...
Old Aug 17, 2007 | 11:16 AM
DonF's Avatar
Default Re: H22 Skunk2 Pro-Series Cams with Type-S Pistons (H22Accord210)
I just degreed ina set Pro2's, on a H22 with one of those dial indicator thingies and degree wheel thingies, and your numbers seem off. Maybe when you get them right it will run better.
Old Aug 17, 2007 | 11:21 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Accord210 &raquo;</TD></TR><TR><TD CLASS="quote">i have a stock bottom end on my h22a and i have pro series stage2 on my head and its has a basic street tune with crome and i am very unhappy with the results it almost feels as if i lost power rather than gain over my stock cams, i have the degrees set up as (3+ on the intake 4+on the exhaust) thats what the tuner said will work but i must say it sux so far. Im going to the dyno pretty soon hopefully they can tune it better than what it is... </TD></TR></TABLE>
like i said on the earlier post i dyno'd a stock H22 with the pro 2's and lost 11 hp. crome tuned... if you want i might know someone who will trade you for the pro 1's. he got a sleeved 14:1 compression motor now and needs some bigger cams. PM SIXTY about it if you are interested. we made 210 on his motor Stock H22 with pro 1's.
Old Aug 17, 2007 | 12:07 PM
Import RP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr &raquo;</TD></TR><TR><TD CLASS="quote">
like i said on the earlier post i dyno'd a stock H22 with the pro 2's and lost 11 hp. crome tuned... if you want i might know someone who will trade you for the pro 1's. he got a sleeved 14:1 compression motor now and needs some bigger cams. PM SIXTY about it if you are interested. we made 210 on his motor Stock H22 with pro 1's. </TD></TR></TABLE>
Was your stock H22 a USDM engine or a JDM one?
Old Aug 17, 2007 | 12:13 PM
Furyof4's Avatar
Default Re: H22 Skunk2 Pro-Series Cams with Type-S Pistons (Import RP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">I just degreed ina set Pro2's, on a H22 with one of those dial indicator thingies and degree wheel thingies, and your numbers seem off. Maybe when you get them right it will run better.</TD></TR></TABLE>
lol...degreeing cams is overrated
Old Aug 17, 2007 | 12:24 PM
h22crxpwr's Avatar
Was your stock H22 a USDM engine or a JDM one?</TD></TR></TABLE>
JDM H22.
Old Aug 17, 2007 | 12:32 PM
2.2EG's Avatar
I made 221 whp with a stock bottom end with my pro 2's, I had a TB and a IM also. but they ran fine in my h22. Thiis was on a VAFC
Old Aug 17, 2007 | 01:25 PM
h22crxpwr's Avatar
Default Re: H22 Skunk2 Pro-Series Cams with Type-S Pistons (2.2EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2EG &raquo;</TD></TR><TR><TD CLASS="quote">I made 221 whp with a stock bottom end with my pro 2's, I had a TB and a IM also. but they ran fine in my h22. Thiis was on a VAFC</TD></TR></TABLE>
what kind of dyno? wheel or hub dyno?
Old Aug 17, 2007 | 04:28 PM
TREVTEC702's Avatar
Dynojet, went 12.1@110 in Vegas, 2200 ft
Old Aug 17, 2007 | 05:41 PM
Import RP's Avatar
Default Re: (h22crxpwr)
I ran the regular stage 2's with no prob on a stock motor with great gains. but pro 2's no way...</TD></TR></TABLE>
How did your results compare with the Stage 2's vs. the Pro1's then? I think the VTEC lobes on the Stage 2's and Pro2's are similar if I'm not mistaken? Obviously the Pro2 has the more aggressive idle lobes though. But here's the specs from Skunk2's 2007 catalog:
-Stage 2-
Intake: 272 deg. duration, 12.8 lift
Exhaust: 280 deg. duration, 11.9 lift
-Pro 1-
Intake: 264 deg. duration, 12.6 lift
Exhaust 264 deg. duration, 11.9 lift
-Pro 2-
Intake: 270 deg. duration, 12.8 lift
Exhaust: 276 deg. duration, 12.0 lift
Old Aug 18, 2007 | 12:30 PM
Mike95lude's Avatar
Default Re: (Import RP)
bump for more input
Old Aug 18, 2007 | 05:16 PM
high_revs's Avatar
intrested in some more imput as well
Old Aug 20, 2007 | 10:26 AM
Import RP's Avatar
Default Re: (h2b_eg8)
Bump for more views
Old Aug 20, 2007 | 04:06 PM
2.2EG's Avatar
here's my Dyno before and after I got the SK2 PRo2's, it would of made more power with a hondata, something other than a VAFC
Old Aug 20, 2007 | 08:23 PM
Mike95lude's Avatar
Default Re: (2.2EG)
Nice thanks for posting that. So do you have JDM or USDM motor? I'm guessing JDM because USDM H22's never make that much torque. Which IM are you running and what size TB. What header are you using too?
Old Aug 21, 2007 | 04:59 AM
IntegraType-R's Avatar
You do realize, like donf stated, and for that matter, every question refering to the pro2's, was always answered by, are the cams degreed in correct...
Those are some Huge cams, they needed to be degreed in to get the correct, lash, the correct clearences and gap info, w/o doing this your trying to **** in the wind basically...i run the s2s2's... leaning towards the pro1's now if that helps.
Old Aug 21, 2007 | 06:17 AM
2.2EG's Avatar
Default Re: (Mike95lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike95lude &raquo;</TD></TR><TR><TD CLASS="quote">Nice thanks for posting that. So do you have JDM or USDM motor? I'm guessing JDM because USDM H22's never make that much torque. Which IM are you running and what size TB. What header are you using too? </TD></TR></TABLE>
yeah it was a JDM motor, I was running a Sk2 IM and a BDL 70mm TB...I the header was a Jasma that was modified with a 2 1/2 collector....The mtor ended up making 258 with some more mods
Old Aug 21, 2007 | 07:58 AM
Import RP's Avatar
Default Re: (2.2EG)
yeah it was a JDM motor, I was running a Sk2 IM and a BDL 70mm TB...I the header was a Jasma that was modified with a 2 1/2 collector....The mtor ended up making 258 with some more mods</TD></TR></TABLE>
Wow, thats very good . Was 258 still with the stock bottom end?
Old Aug 21, 2007 | 06:00 PM
h22sedan's Avatar
Thats pretty impressive.
I was on the phone with Skunk2 today discussing with the tech guy's which cam would be best for my setup. They suggested the Pro 1 cams. He said they usually like to see about 11.5:1 to see good power out of the Pro 2 cams but you totally disproved that.
I've been following this thread for a bit since I'll also be running 11:1 compression. Flat face REV Racing valves and .005" off the head.
Old Aug 21, 2007 | 06:28 PM
2.2EG's Avatar
Wow, thats very good . Was 258 still with the stock bottom end?</TD></TR></TABLE>
No, I put the F22 crank in with the Malhe gold series pistons....I wish I would of had a hondata it would made alot more power than it did....I sold the motor to a friend of mine so it will be tuned on a hondata or chrome pro
