Aftermarket Cluster for S2k
Search turned up nothing.
I remember seeing pics of a Denso cluster for the AP1 from Japan several years ago.
It was a direct replacement for stock, lit up green and had needles for tach/rpm
instead of the segmented LED.
Anyone have more info on availability or links?
This would be installed in an AP2 BTW...
Thank you!
Thank you!
these are the only ones i know of.....
http://www.stackinc.com/display1.html
Spoon made a couple, but good luck getting one of those.....
here is a thread I made way back when.....
https://honda-tech.com/zero...age=1
Modified by cmdr430 at 1:42 PM 8/17/2007
My info is good luck with the Stack cluster. You have to run new sensors for all temp and pressure gauges, plus have a trim piece custom-made ... I think one guy got Bulletproof to do it for him, but it is a PITA either way to install that thing.
It is super conveneint though, so good luck w/ the install if you do it, you'll have a super-rare piece and be able to tell what's going on at the track :D
Supa Troopa
62
Jul 19, 2023 10:07 AM
rasinhell
May 10, 2005 09:17 PM
89DXDann
Jun 4, 2004 11:38 PM
