so im workin on a swap and ran into a little snag
im working on my f22a1 to f22b sohc vtec swap into a 92 accord and ran into a problem.....the fuel line attachment to the fuel rail is on the opposite side......what do i do about this?
Modified by bseriescrxsi at 11:27 PM 8/16/2007
I would go to a local junk yard and pick up a fuel rail with the correct side...any f series would work and i believe some h series fuel rails will work also
does it matter on the injector wiring seeing as im reversing the fuel rail and point of entry for the fuel
no 5g accord came with the fuel rail port on the pass side, so u might need to go aftermarket rail.
from what i remeber, the rails are not interchangable between the f22a and the f22b. so the H-series rails which are the same as the f22a rail wont work either i dont think.
how did you extend it.....if you couple it with an adapter itll blowe right off from the pressure wont it?
Probably braided AN lines.
You could just do that, from the start of the line, but it would be kinda expensive for the lines
