Delsol stopping power
Old Aug 16, 2007 | 02:32 PM
josephshark's Avatar
Default Delsol stopping power
Hey all,
I replaced my rotors and pads a few months ago, with brembo set from 88rotors.com .
couple of questions. Why do these things rust up when it rains, do all rotors do this?
Second, delsol brakes are weak as heck, what can be done about this?
Thx
Old Aug 16, 2007 | 02:41 PM
fdavie's Avatar
Default Re: Delsol stopping power (josephshark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josephshark &raquo;</TD></TR><TR><TD CLASS="quote">Hey all,
couple of questions. Why do these things rust up when it rains, do all rotors do this? </TD></TR></TABLE>
My stock ones will get rusty if they're wet and sitting, but the pads grind away the rust real quick if I'm using the brakes. Are you saying that they rust up even when you're using them?
[QUOTE]Second, delsol brakes are weak as heck, what can be done about this? [QUOTE]
Which Del Sol do you have? The S has small front disks and rear drums, the Si has small front & rear disks, and the VTEC has larger (though not "big") disks all around. If you have an S or Si you could alway swap in the larger brakes off a del sol VTEC or teg (i think they're the same), or invest in a bigbrake kit.
Are you sure its your brakes that are weak, and not your tires? How are you expieriencing weak brakes?
Old Aug 16, 2007 | 02:48 PM
Default Re: Delsol stopping power (fdavie)
I have an si. The rust goes away, but it's annoying though. When I pull away and brake for first time, you hear the grinding of the rust, and sometimes they lock because of the rust albeit only temporarily.
The tires are definitely good, they are only about 10k miles old. I just feel that the brakes are weak & just slow to stop.
Old Aug 16, 2007 | 03:45 PM
t0p_sh0tta's Avatar
Cheap tires and cheap pads destroy braking performance.
Make sure your fluid is fresh also.
Old Aug 16, 2007 | 05:21 PM
Default Re: Delsol stopping power (t0p_sh0tta)
The fluid I don't know about, but the tires are high quality, and the pads are ceramic pbr something or other, they came with the rotors.
Old Aug 16, 2007 | 05:24 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josephshark &raquo;</TD></TR><TR><TD CLASS="quote">The fluid I don't know about, but the tires are high quality, and the pads are ceramic pbr something or other, they came with the rotors. </TD></TR></TABLE>
it's perfectly normal with the rotors, especially if you don't drive the car often.
Azxster
14
Oct 11, 2007 10:07 PM
glulude
May 14, 2007 01:27 PM
Broken Devil
Dec 17, 2004 04:43 PM
eluder33
Nov 15, 2004 09:12 PM
Chemicalviper
Dec 16, 2003 06:34 PM
