Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
neuspeed springs and shockssss???
Old Aug 16, 2007 | 10:29 AM
maxpowers125's Avatar
Default neuspeed springs and shockssss???
are the spring and shock fittings for the 01 coupe and sedan the same or is there some kinda difference in sizing?
Old Aug 16, 2007 | 10:32 AM
daddy's Avatar
Default Re: neuspeed springs and shockssss??? (maxpowers125)
should be the same
Old Aug 16, 2007 | 10:58 AM
InanimateCarbonRod's Avatar
They are essentially the same, except for most spring manufacturers coupe rear springs are different than sedan rear springs because of the weight difference.
Old Aug 16, 2007 | 11:19 AM
jivi's Avatar
Default Re: neuspeed springs and shockssss??? (InanimateCarbonRod)
Yes, true. i have an ES and I'm using the H&R before and rear is sagging, found out the the Spring is for EM2 so i replace it with neuspeed. Neuspeed give a good stance as well.
InvaderTrax
Apr 15, 2007 04:21 PM
GTA
Suspension & Brakes
May 22, 2006 07:49 AM
Wazup
Suspension & Brakes
Feb 6, 2006 10:46 PM
stmotorsports
Nov 20, 2004 11:12 PM
garados
Jan 31, 2002 06:28 PM
