Need advice for MINI ME SWAP!!!
Looking to build a MINI ME swap but need advice from people who have done it before, i have the resources and i know i can get a b16 or a GSR but i like the SOHC better if ant one knows what setup i should use, all suggestion will be greatly appreciated
It depends what car/engine you have.
If you have a d16y7, its best to use a y8 because its easier to work with the head studs.
There is a write up in the FAQ section. Actually, there are 3 different write ups depending on which mini-me your doing. Choose the right one for you.
Good luck
Good luck
EJeff8
12
Oct 3, 2013 08:02 PM
