FS: Integra GSR calipers, S2000 brake upgrade, Civic SiR knuckles, Prelude BMC
JDM Integra GSR gauge cluster - glows amber, low mileage - SOLD
Acura NSX 28T brackets - 110$
This is for a pair of 28T brackets in great condition. They have been milled on the mounting points for Type-R and Legend GS upgrades for 4 bolt Integras and Civics. Retainer clips not included.
Acura Integra GSR front calipers - $85
This is a pair of Integra GSR front calipers with pads from a 99 Integra GSR. They are in great shape. Comes with brackets and pads as pictured. Great upgrade for Civics and older Integras!
RSX Type-S front loaded spindles - 200$
This is a pair of RSX Type-S front spindles. They are 100% complete except for one side missing a lower ball joint. The race for that is in great shape. This is great for those looking to do a 5-lug conversion on a 7th gen civic or early model EP3.
S2000 front 4x100 brake upgrade - $450
This is a pair of calipers from a Mugen brake upgrade for Integras and 10.3" front brake civics. They were cleaned and inspected and found to be in great shape. They were painted silver. This upgrade also includes a pair of new 11.8" rotors, redrilled to 4x100. The brackets have been milled, making this a bolt-on upgrade for Integras and Civic EX models.
Brembo Prelude VTEC rotors redrilled to 4x100 - Brand NEW! - $125
This is a pair of BREMBO 11.1" Prelude VTEC rotors redrilled to the 4x100 bolt pattern. If you have done the front Type-R brake upgrade on a civic/integra, this is the rotor you want. These were redrilled and are new, only mounted for a few seconds on a test knuckle to ensure they fit perfectly hub-centric, and they do. These are brand new, never used and manufactured by the world's leader in rotors, Brembo.
Acura RL big brake upgrade kit - $875
This is the biggest OEM brake retrofit ever to be fitted to a civic. This uses the RL calipers, new 11.8" rotors, a custom bracket, all bolts and caliper hardware, a set of new pads, and a pair of necessary rotor centering rings. Must use knuckles from a Honda that came stock with 9.5" sized front brakes.
97-01 Prelude Brake Master Cylinder - SOLD
Civic SiR 99-00 Front calipers - $45
This is a pair of Civic SiR calipers. Great for doing the 10.3" brake upgrade.
1995 Integra GSR UCAs - $3.
1995 Integra GSR Compensator arms - $3.
These are the Rear Upper control arms, Rear compensator arms, to a 95 Integra GSR. Will fit all 94-01 Integras and 92-95 civics and Del Sols (since they have all the same suspension.) In great shape, the bushings are all good.
D16Y7 Intake manifold - $5
In like new condition, clean, no scratches on face, vacuum line attachment tubes are perfect. Although the pic is bare, it comes with the throttle cable attachment bracket, the intake manifold bracket to bolt to the block, and the hose bracket for the side.
96-98 Sedan 4 door taillights - $20
OEM, Great condition, i kept them waxed all the time. No scratches or nicks, seals are even in great shape.
Rear Disc brake hoses - $10
These are brake hoses for your rear disc conversion. Will fit EKs (96-00 Civics) and probably more.
Modified by BrakeExpert at 2:30 PM 4/20/2008
Any chance you'll be carrying Acura Legend GS Sedan Dual Piston Calipers?
What type of paint did you use for the calipers? I love them s2000 calipers but I'm too poor
Unfortunatly I don't have any rear disc spindles right now. I have this pair of front EX knuckles and I do have the hubs for them and one new ball joint. You'd need to have two new bearings pressed into them. I do have the dust shields for the EX knuckles too, they are just not pictured.
