Loctite Flywheel and pressure plate bolts?
Old Aug 15, 2007 | 09:37 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Loctite Flywheel and pressure plate bolts?
Should I apply Blue (Medium) Loctite onto the flywheel and pressure plate bolts for my ACT flywheel and pressure plate? the flywheel bolts are brand new OEM. I dont want any of these bolts backing out on me but I also dont want to ruin anything by using loctite so i need opinions! Thanks!
Old Aug 16, 2007 | 10:33 AM
pomansouth01's Avatar
Ginger Kid
loctite melts...if you get high heat loctite, it may work but I dont think you need any either way as long as you torque down correctly...
Old Aug 16, 2007 | 11:47 AM
Default Re: (pomansouth01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 &raquo;</TD></TR><TR><TD CLASS="quote">loctite melts...if you get high heat loctite, it may work but I dont think you need any either way as long as you torque down correctly...</TD></TR></TABLE>
does it hurt any if i apply loctite? im using medium blue because i heard red loctite is extremely hard to remove from the threads.
Old Aug 16, 2007 | 12:34 PM
Ginger Kid
I wouldnt do it...if it melts out, it could cause those bolts to loosen a little...
Old Aug 16, 2007 | 08:08 PM
builthatch's Avatar
MiG-21 superfan
i dont use any thread locker with my clutch installs, but...
didn't Clutch Masters include threadlocker with their kits for a long time? i think they did...
Old Aug 16, 2007 | 08:19 PM
miss type r tia's Avatar
I ♥ JDM turbo DC
Default Re: (builthatch)
Since ur flywheel is made of steel then you shouldnt have to worry tooo much about loctitening it. Just make sure you torque it down right. I believe its 3 times. First at 30, then 55, then 76. Have fun and GOOD LUCK! hahahhaa
Modified by miss type r tia at 9:44 PM 8/16/2007
Old Aug 19, 2007 | 03:50 PM
performancespec's Avatar
Default Re: Loctite Flywheel and pressure plate bolts? (JDM turbo DC)
It never hurts to use loctite, but if you plan on removing the item use the blue. Red is permanent and will need to be heated with a torch to remove it. Remember it cures in the absence of air. It will also not "melt" if used on your clutch setup.
Old Aug 19, 2007 | 06:38 PM
Default Re: Loctite Flywheel and pressure plate bolts? (performancespec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by performancespec &raquo;</TD></TR><TR><TD CLASS="quote">It never hurts to use loctite, but if you plan on removing the item use the blue. Red is permanent and will need to be heated with a torch to remove it. Remember it cures in the absence of air. It will also not "melt" if used on your clutch setup.</TD></TR></TABLE>
you think i will have any problems removing the blue loctite off the threads when i remove the bolt?
Old Aug 19, 2007 | 06:49 PM
builthatch's Avatar
MiG-21 superfan
no
Old Aug 19, 2007 | 08:12 PM
Hybrid96EK's Avatar
Default Re: Loctite Flywheel and pressure plate bolts? (builthatch)
I see no reason to loctite either item.
Old Aug 20, 2007 | 06:49 PM
Default Re: Loctite Flywheel and pressure plate bolts? (Hybrid96EK)
but do you see any reason why you shouldnt???
Loctite is good stuff. The blue will actually help against vibration causing the screw/bolt/nut to back out.
Old Aug 20, 2007 | 06:54 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by performancespec &raquo;</TD></TR><TR><TD CLASS="quote">but do you see any reason why you shouldnt???
There is no call for it in the Helm. I have been working on these specific engines (Honda/Acura) since 1996 and have never used Loctite once. To this day, I have never had an issue with flywheel or pressure plate bolts. To me, that is reason enough. If you have THAT much vibration in your crank, I think you have other issues to worry about. Even when using the CTR N1 pulley, I had 0 issues.
Thats like saying "It doesn't say NOT to loctite the crank pulley bolt, so I guess its ok"...
(directed at original poster) You could do whatever you want, its your engine and you are the one who has to remove the parts after loctiting them. Not to be an ***, but if you feel the need, have at it. You asked a public forum for an opinion. If your mind was already made up, why did you bother asking?
Old Aug 20, 2007 | 08:07 PM
tightened up the flywheel bolts without loctite tonite and now debating whether to loctite the pressure plate bolts because they're such a low torque.
Old Aug 20, 2007 | 09:18 PM
garageEF's Avatar
I dont use it, havent ever had any problems....
Old Aug 21, 2007 | 07:13 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC &raquo;</TD></TR><TR><TD CLASS="quote">tightened up the flywheel bolts without loctite tonite and now debating whether to loctite the pressure plate bolts because they're such a low torque.</TD></TR></TABLE>
Lol. Dude, no. They aren't under a lot of torque and don't need to be because you have the constant force of the pressure plate pushing against them. Forget the damn loctite.
Old Aug 21, 2007 | 10:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK &raquo;</TD></TR><TR><TD CLASS="quote">
Lol. Dude, no. They aren't under a lot of torque and don't need to be because you have the constant force of the pressure plate pushing against them. Forget the damn loctite. </TD></TR></TABLE>
yea and there are 9 bolts for my xact flywheel instead of stock which requires only 6 pressure plate bolts. decided not to use loctite at all, thanks everyone.
Old Aug 25, 2007 | 07:42 AM
the question wasnt whether or not he should loctite them because helms does or doesnt call for it, he wants to make sure they dont back out. Its a precaution, nothing more. You can bareback the chick you just met and pull out, it doesnt mean she is not going to get pregnant. using a condom would be a precaution. Hey, we all know it COULD still happen.
Preventative maint is just that. It doesnt garauntee anything but it helps.
Ive been working on many other cars since 1996, and found that many VW, infinitis, etc... use loctite and a majority of their bolts. What does that mean...They spent 4.00 more at the factory than honda did.
(directed at original poster) You could do whatever you want, its your engine and you are the one who has to remove the parts after loctiting them. Not to be an ***, but if you feel the need, have at it. You asked a public forum for an opinion. If your mind was already made up, why did you bother asking?</TD></TR></TABLE>
Old Aug 25, 2007 | 07:52 AM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by performancespec &raquo;</TD></TR><TR><TD CLASS="quote">the question wasnt whether or not he should loctite them because helms does or doesnt call for it, he wants to make sure they dont back out. Its a precaution, nothing more. You can bareback the chick you just met and pull out, it doesnt mean she is not going to get pregnant. using a condom would be a precaution. Hey, we all know it COULD still happen.
but is there a problem with these backing out, ever? if tq'd properly and everything is within reasonable spec, they won't. i've never seen one back out that was torqued properly in 10 years so far. like i said before, i'm pretty sure CM used to include threadlocker with their kits, but maybe that was due to stuff being their spec and not honda's OE flywheel and clutch kit. still, i've never used it as per whatever clutch and flywheel instructions and never had a problem.
i never knew it to really be a concern, but i guess it is lol
btw, do the infiniti and vw use threadlocker on their clutch/fw bolts that you recall?
Old Aug 25, 2007 | 09:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch &raquo;</TD></TR><TR><TD CLASS="quote">
btw, do the infiniti and vw use threadlocker on their clutch/fw bolts that you recall?</TD></TR></TABLE>
Not that i recall, but there is loctite all around the Intake Manifold, TB's etc...
To sum up the argument, If TQed properly it should be fine. It wont hurt to add loctite if you choose to either.
how does that sound?
kris
Old Aug 25, 2007 | 12:21 PM
Scott_Tucker's Avatar
If you use loctine make sure both the male and female threads are clean and dry. Loctite does not work well on greasy bolts. I always use it but I don't think its absolutely necessary and I don't think the bolts will fall out if you don't. If you don't use it make sure you apply a little engine oil or white grease to the threads and torque them properly. All thread should have some sort of lubricant on them. The engine oil or white grease will not make the bolts come out.
Old Aug 25, 2007 | 02:19 PM
95dxsir2's Avatar
Default Re: Loctite Flywheel and pressure plate bolts? (Scott_Tucker)
never heard of applying grease/oil to fly/flex plate bolts. It really doesn't matter. I work for dodge, Flexplates use blue loc-tite, flywheels are dry (even on the cummins engines). it's all up to you. As stated above, use the blue.
Old Aug 27, 2007 | 06:32 PM
maxpsi's Avatar
Default Re: Loctite Flywheel and pressure plate bolts? (95dxsir2)
I only use it because ARP suggested it on their PP and Flywheel bolts. I doubt it will do anything other than its job, and it doesn't effect torque specs as far as I know. I call it added insurance.
Old Aug 28, 2007 | 08:28 AM
Default Re: Loctite Flywheel and pressure plate bolts? (maxpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxpsi &raquo;</TD></TR><TR><TD CLASS="quote">I only use it because ARP suggested it on their PP and Flywheel bolts. I doubt it will do anything other than its job, and it doesn't effect torque specs as far as I know. I call it added insurance.</TD></TR></TABLE>
Yes, insurance is what i have been calling it
Old Aug 28, 2007 | 08:40 AM
Hybrid96EK's Avatar
Yes, insurance is what i have been calling it</TD></TR></TABLE>
After you bolt the engine in the car, you should weld the mounts to the frame for some added "insurance".
Old Aug 28, 2007 | 09:06 AM
maxpsi's Avatar
After you bolt the engine in the car, you should weld the mounts to the frame for some added "insurance".</TD></TR></TABLE>
If your mounts are from Avid, then YES! lol
