94 civic hatch $2200
94 dx hatch fs.
second owner
car was from standford honda
2xxk miles
never swapped. original dx motor/tranny
car was hit and run in rear and just recently the front quarter panel all on the drivers side. cracked rear outer taillight.
black with red strip del sols
jdm lower console.
pioneer cd player (sister lost face) with 6 disc changer and pioneer visual eq
alpine v12 4ch. amp with sub ch.(2ch are not working. need to take in for repair.
both left/right doors with dynomat extreme
floors sprayed with sound deadener
dei alarm with proxy sensor
passenger door lock is not working. the plastic piece that
connects the lines broke.(again for the second time)
it seems to be a common problem.
power door locks work with alarm.
fake mugen style intake box
Skunk2 dual bend shifter with energy susp. shifter bushing
vis cf hood with sparco hood pins
front/rear susp. techniques sway bars
front/rear upper strut bars by cusco
front ingalls camber kit/ rear shim camber kit
front rear gsr brakes with 15/16th master cyl. and goodridges ss lines
front rear axxis metal master pads
energy suspension rear control arm bushings
3 rear windows tinted. not too dark.(forgot %)
rear panels and bench in black tweed
rockford 6.5 components in front and back
Momo steering wheel with release with barrel lock keys
razo (mugen style) clutch/brake pedals
red carpet
piaa horns
gsr wheels powdercoated grey/
all tires bought/put on the same time/ dunlop fm901 205-55-15
fronts have bad camber and rears are good ( sister was using the car and did not balance/rotate wheels/tires regularly)
jdm rs-r ex-mag catback (ordered from japan from modacar. paid $680 before rs-r came to the states)
ground controls with integra spring rates w/ kyb agx 4 way adj. looks like the driver side shock might be out since it sits lower from the accident. (guy on motorcycle hit the front qtr. panel. and took out the cornerlight. the cornerlights were real vision ambers. Im taking the passenger side for memories.
dont have internet, was able to use friends.
best way to contact me is on my cell. (209) 221-3518
Modified by edger8cer at 6:07 AM 8/16/2007
second owner
2xxk miles
jdm lower console.
red carpet
piaa horns
jaje
21
Nov 10, 2008 01:55 PM
