battery drainage? loose ground wire? bad engine??
Old Aug 15, 2007 | 08:56 PM
tinytoon's Avatar
Default battery drainage? loose ground wire? bad engine??
i have a 92 accord ex auto. it will not start on its own and will be required to be jumped started every time the engines cut. once you jump the engine and it runs, you turn on the head lights and boom, the engine dies. i installed brand new fully charge battery with brand new altenator and it turns over once on its own but still dies when headlights get turn on. after when engine dies, it wont turn over anymore besides getting jump started again. can it be a ground wire loose?
Old Aug 15, 2007 | 09:13 PM
phootbag's Avatar
Default Re: battery drainage? loose ground wire? bad engine?? (tinytoon)
I'd perform a voltage drop test. Sounds like you have a bad connection somewhere, corrosion, loose terminal etc...
Old Aug 16, 2007 | 01:08 PM
sony224422's Avatar
Default Re: battery drainage? loose ground wire? bad engine?? (phootbag)
check the alternator ground. and check the chassis ground as well.
Old Aug 16, 2007 | 04:28 PM
Bruce Banner's Avatar
Default Re: battery drainage? loose ground wire? bad engine?? (sony224422)
Do a load test
Mrevann
Mar 4, 2011 08:14 PM
whatisbrokennow
May 3, 2010 03:40 PM
the_dxB16
Sep 5, 2009 09:09 AM
lilshady6796
10
Jun 14, 2009 11:21 PM
96b18c
Jun 3, 2004 07:29 PM
