For those with high mileage EP3/RSX's...
Old Aug 15, 2007 | 07:30 PM
WhiteOnRice's Avatar
Default For those with high mileage EP3/RSX's...
What kind of problems (mechanical, visual, anything) have you experenced? Do the seat bolsters start ripping at 130,000 miles? Clutch burnout? Burn any oil? Etc.
Just want to see what problems happen with our cars so I/we can avoid them.
Out of curiousity, what mileage are you all at with your car?
2002 EP3 - 55,000
Old Aug 15, 2007 | 07:34 PM
IntgrB18C5's Avatar
Default Re: For those with high mileage EP3/RSX's... (WhiteOnRice)
2004 RSX-S with 65,000 and no problems so far except that damn 3rd gear BS but so far
*knock on wood*
Old Aug 15, 2007 | 07:36 PM
.Kevin.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice &raquo;</TD></TR><TR><TD CLASS="quote">What kind of problems (mechanical, visual, anything) have you experenced? Do the seat bolsters start ripping at 130,000 miles? Clutch burnout? Burn any oil? Etc.
2002 EP3 - 55,000</TD></TR></TABLE>
Clutch is user error casing wear. They are going to be like any other honda. Last a long time unless you beat the **** out of it. My last honda(99 civic) was beaten to **** motor wise by myself for two years and nothing broke. The seats would be also determined on how big of a person you are and how you get in and out of the car. My last car (ep3) had the drivers seat sides wearing at 64k. My rsx with 45k has wear in the leather on the drivers seat, but I think that is because the idiot before me never conditioned the leather.
Old Aug 16, 2007 | 04:52 AM
quicksilverdc5's Avatar
banned
Default Re: For those with high mileage EP3/RSX's... (IntgrB18C5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntgrB18C5 &raquo;</TD></TR><TR><TD CLASS="quote">2004 RSX-S with 65,000 and no problems so far except that damn 3rd gear BS but so far
*knock on wood*</TD></TR></TABLE>
I am in the same boat. All cars have there issues but these are awesome cars
Old Aug 16, 2007 | 06:18 AM
JDMk20R's Avatar
03 Base at about 80,000. So far so good, except the 3rd gear synchro thing that Acura fixed a while back
I'm probably just gunna do some minor maintainance on my own ie. replace some hoses, change out fluids, the cabin filter etc.
Old Aug 16, 2007 | 06:51 AM
vltnolia's Avatar
100000 on the clock with no problems. Keep up with general maintenance and your car would be fine.
Old Aug 16, 2007 | 08:18 AM
jdmdc5integra's Avatar
02 RSX-S with 82500 miles and no problems....
Old Aug 16, 2007 | 08:57 AM
Mugen Dom's Avatar
Default Re: For those with high mileage EP3/RSX's... (jdmdc5integra)
at 69k on the EP3 stock motor 69k on the Tein Flex's as well seats are ok lil worn steering wheels the only thing thats a lil worn 7 outa 10 condition paints great but i take care of it
Old Aug 16, 2007 | 09:40 AM
.Kevin.'s Avatar
Default Re: For those with high mileage EP3/RSX's... (JdMK20Ahatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMK20Ahatch &raquo;</TD></TR><TR><TD CLASS="quote">69k on the Tein Flex's as well </TD></TR></TABLE>
That made me
Didnt think the aftermarket set would last that long!
I am assuming you don't have the car "slammed", rather just tastefully lowered.
Old Aug 16, 2007 | 10:32 AM
joey funk's Avatar
Default Re: For those with high mileage EP3/RSX's... (.Kevin.)
05 ep3, just hit 30,000 miles, everything runs great except 4th gear, but i'm getting that fixed asap
Old Aug 16, 2007 | 10:47 AM
Mugen Dom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Kevin. &raquo;</TD></TR><TR><TD CLASS="quote">
That made me
</TD></TR></TABLE>They actually have more than that they were on my coupe for 20k probably...They arent slammed though 3/4 maybe
Old Aug 16, 2007 | 05:04 PM
C4st0r_Tr0y's Avatar
Official H-T Cake Maker
2002 Ep3 - 90k Miles
Only problem is the 3rd gear grind, need to change the syncros
Old Aug 16, 2007 | 05:40 PM
phthalo's Avatar
GDD4LIFE
Default Re: For those with high mileage EP3/RSX's... (C4st0r_Tr0y)
76k...i can't read the numbers on my shift **** anymore
Old Aug 16, 2007 | 11:02 PM
mucter's Avatar
02 Type-S - coming up on 80k...
The leather is cheap and the color wears out on it. When I bought the car with 39k on it the steering wheel was really worn, got Acura to replace it under warranty though, hehe.
Replaced the secondary 02 twice. Finally got K-Pro and turned off the damned code tho, so I don't care about that anymore.
Front rotors are expensive as hell. Don't ever put semi-metallic pads on the front, they will squeel and f-up the rotors. I'm still dealing with that nightmare.
Tranny can grind occasionally in 2nd or 3rd if I drive the car hard before the tranny has time to warm up. Otherwise the tranny is smooth in all gears once warmed up, you just have to shift correctly.
I think the problem that most people don't realize is that the stock clutch starts to grab within an inch of the floor, and most people clutch lazily while shifting quickly, so the tranny never really slows down properly, hence all the 2nd and 3rd gear grinding issues. If I drive properly, I can shift faster than most people and never grind.
This car has been awesome, the perfect blend of luxury and chaos (once I got K-Pro).
Old Aug 17, 2007 | 09:16 AM
T_Virus's Avatar
EP with 66K...only problem is 2nd gear grind
Old Aug 17, 2007 | 10:47 AM
sDc5's Avatar
myself i got me a 05 DC5 type s
currently got 70k+ miles
alot and no more warranty
had a gear and sinkro problem around 30k, (reminder never let your dumb friends try to down shift in your ride) miss shift caused my gears to jam and grind, lucky for me acura covered that one which was not bad and pretty sweet.
than i had a second case. next time you do a tranny flush ONLY use HONDA TRANNY FUILD and it will not fail you, one of my buddies that is a master mechanic for toyota told me ne premium motor oil would work fine, but the thing that he he didn't know was that K20 has some sensitive *** gears so even the tranny fluid matters ALOT. pretty much my tranny started to fall apart after couple months, the motor was running great with regular motor for the tranny but in the long run it kills your gears. bummer for me cuz the 2nd one cost me. and it was big time bucks for labor and parts (15 hundred )
other than the tranny this car is awesom
needs more torque but what honda doesn't nah mean
tranny repairs are the worst
do some research before you follow thru
Old Aug 17, 2007 | 10:49 AM
Brice.Hayden's Avatar
Default Re: (JDMk20R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMk20R &raquo;</TD></TR><TR><TD CLASS="quote">03 Base at about 80,000. So far so good, except the 3rd gear synchro thing that Acura fixed a while back
I'm probably just gunna do some minor maintainance on my own ie. replace some hoses, change out fluids, the cabin filter etc.</TD></TR></TABLE>
was that a recall?
Old Aug 17, 2007 | 01:31 PM
wht_DC5's Avatar
Default Re: (Brice.Hayden)
02 dc5 base model 125,000!!!!!! Hahaha. Still running great and with all bolt-ons. Exhaust, header and intake. No probs at all. **knock on wood**
Old Aug 17, 2007 | 03:12 PM
SuperchargedRSX's Avatar
my 02 RSX-S had 85,000 miles and I did not have a single problem.
my 03 Supercharged RSX-S 60,000 miles and I dont have 2nd gear and my car reving has problems lol (everything will be fixed within 2 weeks)
Old Aug 18, 2007 | 12:19 AM
Heitzke's Avatar
78K on my 02 EP3 and no real problems with anything that it came from the factory with. The only thing I had is the housing of the driver side headlight got really hazy, so I just replaced it. Other than that, it's been great.
Old Aug 19, 2007 | 05:59 PM
05EP3's Avatar
05 EP3 just broke 40k all's good
Old Aug 19, 2007 | 06:39 PM
.Kevin.'s Avatar
Default Re: (05EP3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mucter &raquo;</TD></TR><TR><TD CLASS="quote">02 Type-S - coming up on 80k...
This car has been awesome, the perfect blend of luxury and chaos (once I got K-Pro). </TD></TR></TABLE>
I would say the paint and leather are your own fault. Failure to take care of the car is another story. I can not stress how important it is to use a good leather cleaner and then follow it by a conditioner. For the paint a good coat of a good quality wax will keep the paint looking great.
I am guessing you are using a race header or test pipe. Otherwise you are not buying the plug and play 02 sensors. I personally think the trany grind is user error also. People do not know how to shift and cause it. Mine has 46k and no noises from the trany. I have seen some people drive manual and no wonder trans problems arrise.
Old Aug 20, 2007 | 08:15 AM
RevenantAE's Avatar
2003 RSX-S. At about 60K the drivers side power lock solenoid died. Dealer replaced under AcuraCare warranty (7yrs/100k). Other than that, not a single problem (however, I apply leather care products every few months).
Old Aug 20, 2007 | 09:31 AM
thrty8street's Avatar
Default Re: For those with high mileage EP3/RSX's... (RevenantAE)
the stock mounts on these cars are some ****
Old Aug 20, 2007 | 09:38 AM
.Kevin.'s Avatar
Default Re: For those with high mileage EP3/RSX's... (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">the stock mounts on these cars are some ****</TD></TR></TABLE>
esmm inserts are your friend
