Planning on turbo setup for 2008 ! Need some advice. h22a1 4th gen.
Old Aug 15, 2007 | 04:06 PM
street_ride14's Avatar
Default Planning on turbo setup for 2008 ! Need some advice. h22a1 4th gen.
I'm in the Reasearch stage as of now, so any helpful advice would be appreciated. Not ready for a complete teardown, so basically stock bottom end h22a1. No a/c, PS still intact.
My goal would be to hit high 12's running under 8 psi of boost. This will be daily driven. I'm good with my current suspension setup, so no help needed there. Money is going to be a factor in this build, but not so much as to buying shitty parts that crack all day. Looking at the LoveFab Mini-Me Turbo mani, which turbo would be ideal with this Mani ? I hear the stock Fuel setup works fine for this kind setup. I'm in MA area, so which tuning shop should I go with ? Car is a 1993 Honda Prelude h22a1.
Thanks in advance.
p.s. .... Please don't SpoonFeed, I just need the correct path to follow.
The car ........
Modified by street_ride14 at 7:16 PM 8/15/2007
Old Aug 15, 2007 | 06:52 PM
jdmbreed's Avatar
Default Re: Planning on turbo setup for 2008 ! Need some advice. h22a1 4th gen. (street_ride14)
it all depends on you set up and if you dont have the money to get a good kit or piece one together, i dont see it happening and if it does then you will at sometime need to sleeve your motor..... but i have no idea what 8lbs will put you at for whp range N/A guy not forced induction i say save some money
But damn sexy prelude likin the paint
Old Aug 15, 2007 | 07:36 PM
DfwBB6's Avatar
md23vtec and Oaks watch out here comes another one !!!!
Old Aug 15, 2007 | 07:43 PM
Default Re: Planning on turbo setup for 2008 ! Need some advice. h22a1 4th gen. (DfwBB6)
It'll be long before I can catch up, they'll own Ferraris quicker than I can reach the 10's. I could take a huge loan from the bank, but that would be stupid.
Old Aug 15, 2007 | 08:26 PM
Slick_LudE's Avatar
wow.. high 12s with under 8 psi? Im not sure it can be done... =/
Currently, Im running a 7psi wastegate spring w/ conservative tune. 14.6 with a shitty driver. =P
Of course, I think my motor is toast too. But I've got an h22a4 spare block lying around.
Old Aug 15, 2007 | 09:17 PM
DCxMagus's Avatar
Default Re: Planning on turbo setup for 2008 ! Need some advice. h22a1 4th gen. (Slick_LudE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slick_LudE &raquo;</TD></TR><TR><TD CLASS="quote">wow.. high 12s with under 8 psi? Im not sure it can be done... =/
Of course, I think my motor is toast too. But I've got an h22a4 spare block lying around. </TD></TR></TABLE>
thats pretty bad considering people hit that with minor bolt ons.
isn't the lovefab mini me manifold so the mini me motor set up?
btw your not hitting 12's with the stock bottom end on street tires hehe
read in the boost FAQ lots of info to be had there.
Old Aug 15, 2007 | 09:46 PM
ProjectBB6's Avatar
Default Re: Planning on turbo setup for 2008 ! Need some advice. h22a1 4th gen. (DCxMagus)
You can def hit mid to low 13's with slicks. I have seen high 13's with street tires with people running around 7-8 psi.
BTW 14.6 is just horrible
AR_96
Aug 28, 2009 10:08 AM
whatan00b
Jul 2, 2008 09:32 AM
jxhxb
Sep 30, 2007 03:59 PM
