detonation upon decelaration?
Old Aug 15, 2007 | 08:29 AM
( o )( o )'s Avatar
Default detonation upon decelaration?
I read a lot of archives last night on the topic of detonation.
I see a lot of issues that people have with high compression and too much timing, and one of the common suggestions is to retard the dizzy.
However the symptoms I read about seem to mention the rattling/rocks/bbs noise while the motor is under load, especially around 4000rpm.
My motor works great when I hit the gas so that's why I'm confused.
However, I have noticed at lot lately, that when I decelarate, foot off the gas, wideband reading 19.9, I hear and feel a strange rumble/popping from the engine bay.
Could that be detonation, and if so, how, because I thought fuel stops spraying upon decelaration? or is it ignition that is cut when you decelarate? or both?
I have a b16a2 with CTR cams and pistons and and ITR lsd tranny. I was wondering if perhaps it could be a diff/drivetrain issue.
Any thoughts? I'm not sure what I'm hearing.
Maybe I'll burn another CROME chip with the knock sensor enabled.....
Old Aug 15, 2007 | 08:35 AM
b19coupe's Avatar
Default Re: detonation upon decelaration? (( o )( o ))
It ain't knock. You may be getting some backfire. Unburned fuel igniting in the exhaust system.
Old Aug 15, 2007 | 08:37 AM
mar778c's Avatar
Community Builder
Community Influencer
You need to datalog to know at what manifold pressure and rpm the event is occuring.
But I would recommend turning fuel duration and timing down using crome.
Old Aug 15, 2007 | 09:04 AM
PirateMcFred's Avatar
If you'r running a Honda ECU then when you chop the throttle then the injector duration goes to zero. There should not be any knock at all. There's nothing to burn.
Old Aug 15, 2007 | 09:16 AM
( o )( o )'s Avatar
Default Re: (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">If you'r running a Honda ECU then when you chop the throttle then the injector duration goes to zero. There should not be any knock at all. There's nothing to burn.</TD></TR></TABLE>
That's what I was wondering. This is a 2000 Si with a conversion harness to a p28 socketed with moates.net equipment.
Perhaps its time to invest in datalogging equipment.
Is injector duty cycle and fuel duration the same or two different things? If different, where is that set in CROME?
Old Aug 15, 2007 | 10:13 AM
pasaunde's Avatar
Check you decel fuel with a wide band O2, if its to rich you may be experiencing mild back fire. I just corrected this problem on my car, decel was ~11 AFR way to rich.
Old Aug 17, 2007 | 11:24 AM
( o )( o )'s Avatar
Default Re: (pasaunde)
"Dee Dee Dee!" - Carlos Mencia
It was just a loose tie-rod.
Old Aug 17, 2007 | 03:10 PM
b19coupe's Avatar
Default Re: (( o )( o ))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ( o )( o) &raquo;</TD></TR><TR><TD CLASS="quote"> It was just a loose tie-rod.
It happens to the best of us
00civiccali
16
Jul 8, 2008 08:37 PM
garyc17
May 6, 2007 08:41 AM
SIred91
18
Apr 23, 2007 04:53 PM
cviccoupe
Sep 3, 2006 09:25 PM
SteveeeO
Jun 19, 2003 12:35 PM
