Wednesday will be my last day racing....
For a short while at least.
I have decided to start tearing down my motor and prepare to build.
My plans include:
TWM ITB's
P & P the head
JE 12.5:1 85MM Pistons
GE 85MM Sleeves
Eagle Rods
Some kind of new valves... Ferrea or Manley most likely
Hondata Stage 4
Possibly a different header
Toda Clutch
Toda Flywheel
Quaife LSD
PE Timing Belt
Right now I have:
JUN 3 Cams, springs, retainers, cam gears
JUN Header
JUN Ecu
Stock everything else on a 96-97 JDM ITR
If you have a shop and could possibly sell me ANY or ALL of the items listed at a reasonable price, PLEASE contact me.
nycmad@si.rr.com
Also, What do you guys think about 3" piping? Will this affect performance in a good or bad way?
What kinda power do you think this could throw down with a GOOD tuner?
I have been wanting to do this for a while now, the time is finally here
Thanks,
Miguel
I have decided to start tearing down my motor and prepare to build.My plans include:
TWM ITB's
P & P the head
GE 85MM Sleeves
Eagle Rods
Hondata Stage 4
Toda Clutch
Toda Flywheel
Quaife LSD
PE Timing Belt
Right now I have:
JUN Header
JUN Ecu
nycmad@si.rr.com
Thanks,
Miguel
With a build-up like that, you might wanna think about a Standalone like DFI7 or the AEM instead of Hondata.
Has anyone hasd good luck tuning the Hondata with ITB's?
Suprdave
Suprdave
BTW, off topic, but b18cURmama I was the only HT member at the track last week. We spoke briefly. I only got to see your first run. Good sh#t
[Modified by sando112, 12:39 PM 6/13/2002]
Suprdave
Suprdave
hondata should be fine ...we managed to run it on a 10 second turbo car with no problems ...shouldnt see why it would be a problem in your case ...good luck with your build up ...
NAturalEk9
Mar 25, 2007 01:50 AM
