M22x vs Blox HSL vs Blueprint 2 cams
Old Aug 15, 2007 | 02:58 AM
hondaboyB18C1's Avatar
Default M22x vs Blox HSL vs Blueprint 2 cams
my setup is a B20B bored to 84.50mm & decked .007"
wiesco pistons
Probe "I" beam rods
polished crank
ported , polished , flowed B16 head(stock valves back cut)
milled .020"
68 mm tb
comptech shortram intake( now has Iceman cold air)
knock off Hytech production tri-Y header
M22X Rocket cams (M24X on order)
Supertech springs and retainers
H22 345cc injectors
P28 running crome
sheetmetal intake (now has Skunk 2 Pro series)
stock ignition , fuel pump , fuel rail
2.25 exhaust
Skunk 2 pro cam gears
Greddy timing belt
Built , Tuned & abused by myself
I dynoed the 3 above cams in my B20 vtec on a Dynojet. The smaller M22x cams took out both othe r sets in whp and tourque. i will psot up the graphs later , the numbers were 225/150 sae, more tunning could have been used but each cam was given a fair chance.on the graphs you will also see the rocket cams were tested in 20 degrees F hotter
Rocket cams
I am getting M24x cams next
M22x vs Blox HSL
[IMG][/IMG]
M22x vs Blueprint stage 2
[IMG][/IMG]
Modified by hondaboyB18C1 at 3:06 PM 8/15/2007
Modified by hondaboyB18C1 at 10:05 PM 8/15/2007
Modified by hondaboyB18C1 at 10:08 PM 8/15/2007
Modified by hondaboyB18C1 at 10:17 PM 8/15/2007
Modified by hondaboyB18C1 at 11:45 PM 9/4/2007
Modified by hondaboyB18C1 at 11:46 PM 9/4/2007
Modified by hondaboyB18C1 at 11:47 PM 9/4/2007
Old Aug 15, 2007 | 11:13 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: M22x vs Blox HSL vs Blueprint 2 cams (hondaboyB18C1)
Interesting results Shawn, I know I'm really liking my M22x's. Bruce and I are supposed to be doing some fine tuning this weekend and then I'll be Dynoing FINALLY next week to get some numbers. What's this motor going in?
Old Aug 16, 2007 | 02:50 AM
Default Re: M22x vs Blox HSL vs Blueprint 2 cams (00Red_SiR)
Graph's are up top is M22x vs Blox HSL , bottom is M22x vs Blueprint stage 2
Old Aug 16, 2007 | 02:54 AM
b20beast978's Avatar
big ups to rocket motorsports!
Old Aug 16, 2007 | 04:54 AM
IntegraType-R's Avatar
wonder how the m22x's would perform vs my s2s2's on my 11.8 itb c5
Old Aug 16, 2007 | 06:20 AM
Teamdiesel's Avatar
what are the other mods on that engine setup?
Old Aug 16, 2007 | 06:30 AM
jaydmdude's Avatar
Default Re:
looks like the m22x and the blueprint one has pretty much the same primaries man..the vtec profile is way different. Rocket
Old Aug 16, 2007 | 10:18 AM
UncleD's Avatar
Default Re: Re: (jaydmdude)
Old Aug 16, 2007 | 11:27 AM
this is a comparision on my engine , tuned by myself. remember every setup will act differently to each set of cams
Modified by hondaboyB18C1 at 11:57 AM 8/25/2007
Old Aug 16, 2007 | 11:42 AM
Teamdiesel's Avatar
bump, what were the supporting mods on this setup?
Old Aug 16, 2007 | 04:28 PM
Default Re: (Teamdiesel)
wiesco pistons
Probe "I" beam rods
polished crank
milled .020"
68 mm tb
knock off Hytech production header
M22X Rocket cams (did have Blox HSL & Blueprint cams)
H22 345cc injectors
P28 running crome
sheetmetal intake with velocity stacks (trying Performer X soon )
2.25 exhaust
Greddy timing belt
Old Aug 16, 2007 | 05:20 PM
96Spec Ek's Avatar
Default Re: (hondaboyB18C1)
Not to be an ******* but on the first graph the two runs were on different days. The temperature difference was 20 degrees cooler and the humidity was 24% less on the run which made more power. The second sheet I can't really read but it is also on different days where conditions where not the same. Nice power but not a very accurate comparison between the cams.
Old Aug 16, 2007 | 07:50 PM
B18cHatch06's Avatar
Default Re: (96Spec Ek)
you have it all wrong..the 1 that made more power was on a hotter day with more humidity
Old Aug 17, 2007 | 03:00 AM
Default Re: (B18cHatch06)
it wasn't a hotter day , I live in Nova Scotia it was a misty night from cool fog
Old Aug 18, 2007 | 12:50 PM
Rocket's Avatar
Do you understand SAE correction? If you don't please educate yourself.
SAE Correct will not equal (emphasis added for clarity) Un-corrected (actuall) unless conditions such as temp, baro and humitidy are at standard SAE levels.
Old Aug 18, 2007 | 12:57 PM
Rocket's Avatar
Default Re: (Master of the Universe)
So on different days the motor makes more power after a certain rpm and the same power before that certain rpm?
Sorry, I wasn't going to post here as it is not really my place but had I have to correct some whacked-*** logic/ill-logic.
Old Aug 20, 2007 | 05:27 AM
the cams landed the same result order in whp SAE & UNCORECTTED
Modified by hondaboyB18C1 at 11:59 AM 8/25/2007
Old Sep 1, 2007 | 03:42 PM
M24X cams comming soon
Old Sep 1, 2007 | 04:50 PM
98vtec's Avatar
moderator emeritus
please add your complete setup to the first post. I am adding this to the faq
Old Sep 1, 2007 | 09:26 PM
UncleD's Avatar
Default Re: (98vtec)
Bump for "Chillinit"
Old Sep 2, 2007 | 07:46 AM
Rollo Lawson's Avatar
Default Re: (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Bump for "Chillinit" </TD></TR></TABLE>
who cares, loser. Chillinit has no problem with Rocket or his products, its u, moron. bump, so that Chillinit can tell u where to go. Jackass. u had very little knowledge, if any about cam design, ramp speeds, lift, duration, lobe thickness...nothing when i pm'd u. chillinit is a designer, and u are a internet salesman thats talks out of his ***.
Modified by Rollo Lawson at 12:03 PM 9/2/2007
Old Sep 2, 2007 | 08:41 AM
UncleD's Avatar
Default Re: (Rollo Lawson)
Wow, didn't realize you knew me so well guy!
I have no recollection of a conversation with you via pm, but whatever....have a nice day.
Old Sep 2, 2007 | 08:59 AM
mtber's Avatar
Another thing you may want to do is note which run is what cam setup i.e. run 24 = rm cams...
Old Sep 2, 2007 | 09:01 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboyB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
wiesco pistons
What is your estimated compression ratio ?
Old Sep 2, 2007 | 09:56 AM
b20vtech's Avatar
whats ur compression ratio on this motor?
