type r build
C5 build for EG hatch track car.
fresh block:
squirters in first:
pics of goodies:
love it when they are see through , lol:
cam closest is toda stage 2 or spec b whatever the *** they wanna call it , lol , furthest is typeR cam , difference is sickening , lol.
pistons ringed cleaned oiled , bores oiled , and installed in block:
closeup , ahh beatiful , they are 11.5:1.
main bearings in , lubed ready for new eagle crank:
crank in and torqued:
the flywheel hes running , 8lbs or somin close to that , light as hell , hes also gonna run XTD stage 3 6 puck:
head and oil pump and rear main seal on:
cams in , holders torqued , water pump , blah blah blah:
couple pics of the car:
gutted big time , 12 point cage in it. supposedly weighs in at 1500 lbs , wow , this thing will smoke with that engine in it. its too bad he didnt have some valvetrain so he could run those toda cams. there too big for typeR train.
heres some more pics , getting there. hes still missing a few parts , i robbed every piece and bolt i could off the engines and parts i have around here , lol. we need 14mm half shaft bolts. they are different than your normal 14mm bolt. he needs the long alternator bolt and nut. he needs a short 14mm bolt that holds the breather box on the back of the block. he doesnt have the brace that holds the IM to the block , but he can get away without that i suppose. he doesnt have an oil pickup or baffle plate , im pretty sure they are all the same and i have a pickup and bafle plate for an LS engine here. anyways , the problem i was having with bearings was this , they came back from machine shop with 2 of the caps on the wrong rods and they arent numbered , marked , *** all. it was the slight color difference that finally gave it away. so its good to go , torqued and almost ready.
after i went at the badges with progressively fine sand paper
stole timing covers and stuff i had to finish it as stock as i could
fresh block:
squirters in first:
pics of goodies:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch »</TD></TR><TR><TD CLASS="quote">why the eagle crank,then stock pistons and rods.are those cranks balanced good. not bashing just wondering,by the way everything looks good. should scream in that car</TD></TR></TABLE>are you blind?those are not stock pistons.they maybe stock rods but there is no way in hell there stock pistons.
yea those pistons dont look stock. the rods look stock but not the pistons. eagle cranks are pretty good i have used there 95mm stroker crank for b18 and i loved it but then again i had the entire assembly balanced. 85mm bore 95mm stroke was a beast of an engine.
http://cgi.ebay.com/ebaymotors...wItem
actually your blind. heres your forged pistons. you need to get facts straight before u look like a idiot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch »</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...wItem
actually your blind. heres your forged pistons. you need to get facts straight before u look like a idiot</TD></TR></TABLE>umm ok they aren't forged there cast pistons but there not oem pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch »</TD></TR><TR><TD CLASS="quote">why the eagle crank,then stock pistons and rods.</TD></TR></TABLE>so i'm going off of what you posted.and fyi i'm not the idiot that said stock pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready »</TD></TR><TR><TD CLASS="quote"> its too bad he didnt have some valvetrain so he could run those toda cams. there too big for typeR train.</TD></TR></TABLE>
All that work and no valve train? Bigger cams would really wake the motor up, but it should still be a fun ride
no one failed to mention or ask about the compression...those pistons was said to be 11.5 comp...man they look similar to ctr pistons to me but just reworked on the mill...so maybe they are 11.5 cr...who knows but looks sick...
dude wtf? those r not oem pistons lol honda doesnt use teflon coating atleast to my knowledge. chill out.
all i was saying is why use a eagle crank and stock rods and pistons{not honda but still cast}. i thought that maybe there was a reason for it i wasnt aware off,so i asked since i love to learn new things. when i say stock i meant a cast piston. when somebody starts a post off directed to me with are u blind i get defensive,as would anyone. i dont want to trash this thread cause it looks like a killer setup that deserves props. now lets see some #'s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMOGGY »</TD></TR><TR><TD CLASS="quote">verrrrnice!</TD></TR></TABLE>
sick looking eh as well. full race eh :drool:
RBaluca.com
Dec 14, 2007 11:32 AM
Josh
Aug 7, 2001 08:53 PM
