engine starting trouble need help
Old Aug 15, 2007 | 12:16 AM
Jdmhonda26's Avatar
Default engine starting trouble need help
i just got done swapping my b16 dohc obd0 motor an its not firing--i have spark an i also have fuel an everthing is connected an usin a b18 dohc teg ecu...i also tryied to jump the timing but no help any suggestions..? thank you
Old Aug 15, 2007 | 05:10 AM
juanchoenuncrx's Avatar
* B A N N E D *
Default Re: engine starting trouble need help (Jdmhonda26)
HAVE YOU DONE ALL THE GROUND WIRES? CAUSE IF YOU DONT DO THE VALVE COVER GROUND WIRE IT WONT START......
Old Aug 15, 2007 | 05:20 AM
1 Fly SI's Avatar
Is your ecu getting power?
Old Aug 16, 2007 | 09:24 PM
Jdmhonda26's Avatar
yes all of my grounds r hooked up an my ECU is powered but i found my problem-it ws the ******-rig wiring that was under my dash that i just discoved for the first time. an i got my motr running..Thank you for giving me tips
Old Aug 17, 2007 | 04:54 AM
EGlovr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmhonda26 &raquo;</TD></TR><TR><TD CLASS="quote">yes all of my grounds r hooked up an my ECU is powered but i found my problem-it ws the ******-rig wiring that was under my dash that i just discoved for the first time. an i got my motr running..Thank you for giving me tips</TD></TR></TABLE> what?
91hatchproject
Sep 9, 2011 07:12 PM
BKGuy
Oct 29, 2008 11:47 AM
mark31kiss
Mar 27, 2007 03:41 PM
2kTeg
Mar 25, 2006 09:53 PM
MM's94Civic
Jun 25, 2004 09:42 PM
