Help me choose a H22 N/A race cam!!!
I'm building a new setup for this year and looks like i narrowed it down to 3 companies that may benefit my engine program. I've already done my research on all 3 choices using the ever so popular SEARCH feature here and found nothing that can help with my decision. So if anyone has had any experience using anyone of these companies or if any of these manufacturers/vendors/camshaft guru's can chime in or if anyone can point me in the right direction, feedback and/or contact information will definitely be appreciated. Thanks!
Here are the specs on the motor FYI....
Alaniz Head
90.5mm bore X 95mm stroke (with a stroker motor along the way
13:1+ CR
Thanks Again!
Alaniz Head
)13:1+ CR
Thanks Again!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorRandy »</TD></TR><TR><TD CLASS="quote">using the ever so popular SEARCH feature here and found nothing that can help</TD></TR></TABLE>
I know how you feel....
I personally like the Farrera/Crane vtec killa cams setup but my motor is still stock so don't listen to me.
Who's your block sleeved by and what pistons and rods are you going with?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserious »</TD></TR><TR><TD CLASS="quote">You might as well set yourself up for the future and get the Ferrea rollers. </TD></TR></TABLE>
Thats exactly what im thinking..... Thanks Seth!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88ED8 »</TD></TR><TR><TD CLASS="quote">
Who's your block sleeved by and what pistons and rods are you going with?</TD></TR></TABLE>
Block was sleeved by Golden Eagle, Arias Pistons and Saenz H22 Rods.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTY »</TD></TR><TR><TD CLASS="quote">Madness has some
https://honda-tech.com/zerothread?id=2052225</TD></TR></TABLE>
Yeah i know....
Yeah i know....
if my vote maters ill vote roller rockers. i eventually plan on getting some, and hopefully by then someone will have some sick profiles ready. im sure that the ferrea's could be improved upon.
is there even a single person out there using the roller setup?
Leslie ran web extended rocker pads with her B, as does Bisi with his F from what I understand. It seems the cars running the exteneded pads went faster and made more power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hardt »</TD></TR><TR><TD CLASS="quote">Leslie ran web extended rocker pads with her B, as does Bisi with his F from what I understand. It seems the cars running the exteneded pads went faster and made more power.</TD></TR></TABLE>
LOL..... you know i had to come on to H/T and ask right?
Despite all the feed back and the poll votes..... seems like i've been hearing a great many things about Web Cam. Anyone have any experience with their VTEC eliminator setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTY »</TD></TR><TR><TD CLASS="quote">If the rollers are even an option you must be ballin'
LOL... that is definitely not true.....
I just want the best bang for the buck
</TD></TR></TABLE>LOL... that is definitely not true.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FLATBUSH PROJECTS »</TD></TR><TR><TD CLASS="quote">have you ever considered OBX cams?
oh to match the new OBX roller rockers too right.
</TD></TR></TABLE>oh to match the new OBX roller rockers too right.
We just got the extended rockers back in production again. We've seen a great amounts of gains by being able to run more than .500 lift. I know other companys CLAIM that their camshafts do have more than .500 lift but the LMA could only let you do so much. I will be putting in these rockers and cams in my turbo car and all motor car. I will show the gains...
The fastest all motor B used Web...maybe there is a pattern there...
...extended rocker pads are amazing...I would know! If you love weight, and some nice friction with it...then go roller.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bisimoto »</TD></TR><TR><TD CLASS="quote">The fastest all motor B used Web...maybe there is a pattern there...
...extended rocker pads are amazing...I would know! If you love weight, and some nice friction with it...then go roller.</TD></TR></TABLE>
Enough said
Thank you Bisi
Enough said
Thank you Bisi
